Millermatic 200
1917
Loysville Pa
I have the opportunity to buy a millermatic 200 for $200.00. No tank comes with it but it has a new gun on it.The problem is it welds good and is not abused and was not used much but every so often smoke comes out from the unit.My old boss has it so I know the history on the machine.Does anyone have any input on this model or have any suggestions.
steelsoldiers
3,984
Charleston, WV
That's one heck of a deal! I paid over a grand for my MM210 with a bottle of gas, extra wire, and accessories. Like Lanty said, even if you need to have it repaired, you still come out great on the deal. Your local welding gas outfit should be able to hook you up with a bottle lease pretty reasonably.
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
I've got a 200 miller, and am happy with it. But the only thing I have to compare it to is a 110v cheapo welder. Traded repairing a forklift, and moving a stamping press to get it. It was one of 5 that needed looking at or repairing, most problems were with the switches, or corroded contacts on the relays.
Dennis
m16ty
218
Dickson,TN
Sounds like a good deal but the smoke issue has me a little concerned. Remember that after a welder looses all it's smoke it won't work anymore :wink:.
Rattlehead
Michigan
I have an older Millermatic 200 and have run numerous 35 lb wire spools through it without a hitch. The only thing I have done on it was to replace the gun's trigger last year after dropping it.
If you find out the repairs will be too costly, I might be interested in buying the gun and cables.
WPNS421
Cantley Quebec
As said before $200 for a used Millermatic is a steal, the smoke might be from dust and dirt that have entered into the machine and when it heats up these particles burn and create the smoke. Buy it and take it to a Miller dealer and have him look at it, he will tell you what is wrong and what it will cost to repair it. Trust a brand name a no name machine means no service or parts further down the road.
Nonotagain
41
Parkville, MD
The gears for the wire feed sit right above a high voltage tap. If the connections to the tap are loose they can heat up with use and any grease that flings off the gears will smoke.
Tighten up the connections and lightly lube the gear shafts with high temperature silicone grease.
If the smoke does not smell "electricial" in nature and is not constantly seen it's probably not a cause for concern.
yeager1
Colorado
I have a larger version of that welder and have hundreds if not thousands of hours on it with no problems, just basic maintenance on the gun/liner. Great unit, get it and clean it out well (the fan may have pulled a lot of junk in- get it and clean it good and run it). I clean mine with an air gun regularly due to dust issues. Even if it need some repair its still a good deal. Of my 5 welders, it's still my favorite for most tasks (in that amp range).
