missing shims on mep-003a
peyton
10
houston, tx
years ago i bought, sight unseen, a mep-003a which, as it turned out, was missing the injection pump and shims. so how does one measure or calculate the shims needed? please point me in the right direction if this has been previously discussed.
thank you, peyton
Ray70
5,795
West greenwich/RI
You want page 136 and 137 in the -34 TM. Measure from the face of the pump mounting surface to the cam right next to the gear, subtract 1.171" and the difference is the required shim thickness.
I have a bunch of new shims if you can determine what thickness you need.
The shim is specific to the block, so regardless of the IP you install, the block shim will remain the same.
peyton
10
houston, tx
thanks ray for the push in the right direction. the mep003a is currently in storage and won't be disturbed for a while yet ... i am in the studying/learning (hopefully) stage right now. as for shims, years ago i bought a new injection pump along with a kit containing buttons and a set of 4 shims. hopefully, when the time comes, that will be all i need.
thanks again, peyton
Ray70
5,795
West greenwich/RI
You should be good then! It typically doesn't take very much shim thickness to get there.
Glad you have timing buttons. Some are available pretty cheap ( the thinner ones no one ever needs ) but the thick ones #14+ went through the roof in price a couple years ago. It was like $10 for a thin button and $150 if you desperately needed a #15 and got gouged by the 1 guy who had one available.
