Missing switch
Oasis
MI
I have a 2010 Mep-806B and I am missing some part and hope someone has one or knows where I can get one without going broke. first is an Ac circuit interrupt toggle switch and if you do have one I could use the wiring diagram to wire it up it consists of the five-wire need to know where they all go. Thanks for your help
Light in the Dark
5,518
MA
Welcome. For starters, pull down all the related technical manuals for this machine. They can be found here: https://www.steelsoldiers.com/threads/manuals-for-the-mep-806b.173099/
The information you seek on the toggle will be found in the TM 9-6115-672-24P book. Or at least enough info to secondarily find the vendor and manufacturer number if its not outright listed. Find the parts diagram of the panel, and you should be well on your way to finding the info you seek.
You will also find wiring information in this book (and it should be on a data plate somewhere on the machine, if its anything like the smaller sets).
Oasis
MI
thank you for taking the time to help me out. I had the NSN # 5930013725387 but most companies that have this are asking stupid Money for it. it should be around twenty Dollars or less its a toggle switch
