mixed dot 3 and 5 brake fluid
2deuce
147
portland, oregon
I just got my new truck home last night. It is still on the trailer. Good truck except it has a brake problem. It is an air force deuce with the dual system. The brakes work if you pump them 3 times or more getting more pedal each pump. It will hold until you release the pedal and then you must pump again. I looked in the MC and it looks thick and unmixed. The door to the MC has a stencil on the bottom side that says to use Dot 3. This could be a job with the 2 air packs and I'm trying to get as much info as possible before I start. I don't know anything about what was done before, whether it was purged of the dot 5 before dot 3 was used or not. My hunch is unless it was done by the military, the fire dept I got the truck from would not have done a change, only added the 3. I posted this to see what you guys would do, and if you have encountered this problem personally.
Scrounger
66
Southern, Maryland
With the right tools it isn’t that bad a problem if there are no seal issues. The first question is what brake fluid you wish to have in it. If it were my vehicle, I would put DOT 5 fluid. What is needed is an adapter for the master cylinder(s) to pressurize the system with air. Acetone for cleaning the lines. And a pressure brake bleeder.
Start by blowing out the old fluid with compressed air, working front to back. That means MC(s), air pack(s), then wheel cylinders. Then fill the master cylinder(s) with acetone and repeat the process. It doesn’t hurt to repeat the process a couple of times. The idea is to remove all the old fluid. Then blow compressed air thru the system to make sure it is dry.
Then refill the system with your brake fluid of choice and bleed it as normal.
No matter what the system is going to have to be flushed. When you clean and repack the wheel bearing you can inspect the wheel cylinders if nothing has started to leak.
2deuce
147
portland, oregon
It might be difficult to pressurize the MC because it just has a plastic screw on cap. I was leaning toward using Dot 3, because if it needed flushing a few times I could afford it. I didn't know Acetone would be safe to use, I thought it would damage anything rubber. It acts like there is a lot of air in the system, the MC may have run dry at some point, then 3 was used.
Scrounger
66
Southern, Maryland
There was a bulletin some years ago about flushing out a contaminated system and acetone was what was called for.
As for using compressed air. It doesn’t take much pressure, just a couple of psi. An oversized rubber stopper with a blow gun works for the master cylinder. That just means it will take soldier A for pressurizing and soldier B for the bleeding part.
One of the nice things about using DOT 5 is it lasts longer. What most don’t realize is DOT 3 should be replaced every couple of years.
rustystud
2,779
Woodinville, Washington
Never use "Acetone" to flush out any brake system. Acetone is used in the production of rubber seals but only as a "release" agent as it "softens" the rubber. Also never use alcohol to clean out a brake system. If you need to flush the system to get out debris then use the brake fluid it had in it to flush it out with. As your system has already been contaminated by the DOT 3 fluid I would completely rebuild it and replace all seals and wheel cylinder cups. Using brake cleaner to flush out all the brake lines. Silicone brake fluid is suppose to be only used with "EPDM" and "Viton" seals. So your system (if it has not been changed since the military had it) would have those seals.
frank8003
4,983
Ft. Lauderdale, Florida
Some of the attached may help
This is my best files on the subject and it belongs in here due to the title.
View attachment DOT 3 Dot 5 brake fluid 01042018 pro.docxView attachment DOT 5 MIL-PRF-46176B[1].pdfView attachment DOT brake fluid secrets.pdfView attachment TB43-0002-87 replacement procedure brake fluid.pdf
The TB 43-0002-87 02051982 is probably what you need to comply with but since I was searching thru 12GB of files I put the other attachments here into SS so they don't get "lost".
.........and NO, I do not know why I see just big black boxes or just little white boxes but click on it and it should work, haven't figured that one out yet. Also I would attach my own .DOCX file here for brevity but that is disallowed so here is copy paste. fm
Battle of the Brake Fluid DOTs
DOT 3-4 Verses DOT 5. Which brake fluid should I use? {Dot 5.1 has nothing to do with this}
From Oak Okleshen #35 "With regards to the DOT 3-4 verses DOT 5 brake fluid controversy, here is an article sent to me by Mr. Steve Wall. It is one of the most professional treatments I have seen on the subject".
[I had to condense this article from 6 pages to 1 due to space limitations – [fm]
Brake Fluid Facts
by Steve Wall
As a former materials engineering supervisor at a major automotive brake system supplier, I feel both qualified and obligated to inject some material science facts into the murky debate about DOT 5 verses DOT 3-4 brake fluids. The important technical issues governing the use of a particular specification brake fluid are as follows:
1. Fluid compatibility with the brake system rubber, plastic and metal components.
2. Water absorption and corrosion.
3. Fluid boiling point and other physical characteristics.
4. Brake system contamination and sludging.
Additionally, some technical comments will be made about the new brake fluid formulations appearing on the scene.
First of all, it's important to understand the chemical nature of brake fluid. DOT 3 brake fluids are mixtures of glycols and glycol ethers. DOT 4 contains borate esters in addition to what is contained in DOT 3. These brake fluids are somewhat similar to automotive anti-freeze (ethylene glycol) and are not, as Dr. Curve implies, a petroleum fluid. DOT 5 is silicone chemistry.
Fluid Compatibility
Brake system materials must be compatible with the system fluid. Compatibility is determined by chemistry, and no amount of advertising, wishful thinking or rationalizing can change the science of chemical compatibility. Both DOT 3-4 and DOT 5 fluids are compatible with most brake system materials except in the case some silicone rubber external components such as caliper piston boots, which are attacked by silicon fluids and greases.
The big bugaboo with DOT 3-4 fluids always cited by silicone fluid advocates is water absorption. DOT 3-4 glycol based fluids, just like ethylene glycol antifreezes, are readily miscible with water. Long term brake system water content tends to reach a maximum of about 3%, which is readily handled by the corrosion inhibitors in the brake fluid formulation. Since the inhibitors are gradually depleted as they do their job, glycol brake fluid, just like anti-freeze, needs to be changed periodically. Follow BMW's recommendations. DOT 5 fluids, not being water miscible, must rely on the silicone (with some corrosion inhibitors) as a barrier film to control corrosion. Water is not absorbed by silicone as in the case of DOT 3-4 fluids, and will remain as a separate globule sinking to the lowest point in the brake system, since it is more dense.
Fluid boiling point
DOT 4 glycol based fluid has a higher boiling point (446F) than DOT 3 (401F), and both fluids will exhibit a reduced boiling point as water content increases. DOT 5 in its pure state offers a higher boiling point (500F) however if water got into the system, and a big globule found its way into a caliper, the water would start to boil at 212F causing a vapor lock condition [possible brake failure -ed.]. By contrast, DOT 3 fluid with 3% water content would still exhibit a boiling point of 300F. Silicone fluids also exhibit a 3 times greater propensity to dissolve air and other gasses which can lead to a "spongy pedal" and reduced braking at high altitudes.
DOT 3 and DOT 4 fluids are mutually compatible, the major disadvantage of such a mix being a lowered boiling point. In an emergency, it'll do. Silicone fluid will not mix, but will float on top. From a lubricity standpoint, neither fluids are outstanding, though silicones will exhibit a more stable viscosity index in extreme temperatures, which is why the US Army likes silicone fluids. Since few of us ride at temperatures very much below freezing, let alone at 40 below zero, silicone's low temperature advantage won't be apparent. Neither fluids will reduce stopping distances.
With the advent of ABS systems, the limitations of existing brake fluids have been recognized and the brake fluid manufacturers have been working on formulations with enhanced properties. However, the chosen direction has not been silicone. The only major user of silicone is the US Army. It has recently asked the SAE about a procedure for converting from silicon back to DOT 3-4. If they ever decide to switch, silicone brake fluid will go the way of leaded gas.
The single most common brake system failure caused by a contaminant is swelling of the rubber components (piston seals etc.) due to the introduction of petroleum based products (motor oil, power steering fluid, mineral oil etc.) A small amount is enough to do major damage. Flushing with mineral spirits is enough to cause a complete system failure in a short time. I suspect this is what has happened when some BMW owners changed to DOT 5 (and then assumed that silicone caused the problem). Flushing with alcohol also causes problems. BMW brake systems should be flushed only with DOT 3 or 4.
If silicone is introduced into an older brake system, the silicone will latch onto the sludge generated by gradual component deterioration and create a gelatin like goop which will attract more crud and eventually plug up metering orifices or cause pistons to stick. If you have already changed to DOT 5, don't compound your initial mistake and change back. Silicone is very tenacious stuff and you will never get it all out of your system. Just change the fluid regularly. For those who race using silicone fluid, I recommend that you crack the bleed screws before each racing session to insure that there is no water in the calipers.
New developments
Since DOT 4 fluids were developed, it was recognized that borate ester based fluids offered the potential for boiling points beyond the 446F requirement, thus came the Super DOT 4 fluids - some covered by the DOT 5.1 designation - which exhibit a minimum dry boiling point of 500F (same as silicone, but different chemistry).
Additionally, a new fluid type based on silicon ester chemistry (not the same as silicon) has been developed that exhibits a minimum dry boiling point of 590F. It is miscible with DOT 3-4 fluids but has yet to see commercial usage.
http://www.afcoracing.com/tech_pages/fluid.shtml
Automotive brake fluid has many responsibilities. Corrosion protection and lubrication of brake system components are only a portion of the role brake fluid must play.
All automobiles that have a hydraulic braking system must use brake fluid in order for the brake system to operate. The type of fluid used can depend on the type of vehicle and the demands of the vehicles brake system.
The two most common brake fluids used in the automotive industry are fluids that contain Polyalkylene Glycol Ether and fluid that contains Silicone or Silicium-based Polymer. Both Fluids are common but very different in regards to the manner in which they perform. Fluids containing Polyalklene Glycol Ether are more widely used and are the only fluids that should be used in racing brake systems.
Because brake systems may reach extreme temperatures brake fluid must have the ability to withstand these temperatures and not degrade rapidly.
SILICONE BASED FLUID
Fluids containing Silicone are generally used in military type vehicles and because Silicone based fluids will not damage painted surfaces they are also somewhat common in show cars.
Silicone-based fluids are regarded as DOT 5 fluids. They are highly compressible and can give the driver a feeling of a spongy pedal. The higher the brake system temperature the more the compressibility of the fluid and this increases the feeling of a spongy pedal.
Silicone based fluids are non-hydroscopic meaning that they will not absorb or mix with water. When water is present in the brake system it will create a water/fluid/water/fluid situation. Because water boils at approximately 212º F, the ability of the brake system to operate correctly decreases, and the steam created from boiling water adds air to the system. It is important to remember that water may be present in any brake system. Therefore silicone brake fluid lacks the ability to deal with moisture and will dramatically decrease a brake systems performance.
POLYGLYCOL ETHER BASED FLUIDS
Fluids containing Poly glycol ethers are regarded as DOT 3, 4, and DOT 5.1. These type fluids are hydroscopic meaning they have an ability to mix with water and still perform adequately. However, water will drastically reduce the boiling point of fluid. In a passenger car this is not an issue. In a racecar it is a major issue because as the boiling point decreases the performance ability of the fluid also decreases.
Poly glycol type fluids are 2 times less compressible than silicone type fluids, even when heated. Less compressibility of brake fluid will increase pedal feel. Changing fluid on a regular basis will greatly increase the performance of the brake system.
FLUID SPECIFICATIONS All brake fluids must meet federal standard #116. Under this standard is three Department of Transportation (DOT) minimal specifications for brake fluid. They are DOT 3, DOT 4, and DOT 5.1 (for fluids based with Polyalkylene Glycol Ether) and DOT 5 (for Silicone based fluids).
MINIMAL boiling points for these specifications are as follows:
Dry Boiling Point Wet Boiling Point
DOT 3 401ºF 284º F
DOT 4 446º F 311º F
DOT 5 500º F 356º F
DOT 5.1 518º F 375º F
Racing brake fluids always exceeds the DOT specifications for dry boiling points. Wet boiling points generally remain the same.
DOT 3 VS. DOT 4 and 5.1
AFCO's 570º brake fluid is a DOT 3 type fluid. However, it has a dry boiling point that is 52º higher than DOT 5.1 specifications, 124º higher than DOT 4 specifications and 169º higher than DOT 3 specifications. AFCO's 570º fluid meets or exceeds all DOT 3, 4, and 5.1 lubrication, corrosion protection and viscosity specifications.
AFCO's 570º racing fluid meets but does not exceed federal standards for wet boiling point specification; therefore, its classification is DOT 3. Because AFCO's 570º fluid is intended for use in racing type brake systems that undergo frequent fluid changes, exceeding federal standards for wet boiling points is of little concern. Racing brake fluids always exceeds the DOT specifications for dry boiling points. Wet boiling points generally remain the same.
WET VS. DRY BOILING POINT
The term boiling point when used regarding brake fluid means the temperatures that brake fluid will begin to boil.
WET BOILING POINT
The minimum temperatures that brake fluids will begin to boil when the brake system contains 3% water by volume of the system.
DRY BOILING POINT
The temperatures that brake fluid will boil with no water present in the system.
MOISTURE IN THE BRAKE SYSTEM
Water/moisture can be found in nearly all brake systems. Moisture enters the brake system in several ways. One of the more common ways is from using old or pre-opened fluid. Keep in mind that brake fluid draws in moisture from the surrounding air. Tightly sealing brake fluid bottles and not storing them for long periods of time will help keep moisture out. When changing or bleeding brake fluid always replace master cylinder caps as soon as possible to prevent moisture from entering into the master cylinder. Condensation, (small moisture droplets) can form in lines and calipers. As caliper and line temperatures heat up and then cool repeatedly, condensation occurs, leaving behind an increase in moisture/water. Over time the moisture becomes trapped in the internal sections of calipers, lines, master cylinders, etc. When this water reaches 212º F the water turns to steam. Many times air in the brake system is a result of water that has turned to steam. The buildup of steam will create air pressure in the system, sometimes to the point that enough pressure is created to push caliper pistons into the brake pad. This will create brake drag as the rotor and pads make contact and can also create more heat in the system. Diffusion is another way in that water/moisture may enter the system.
Diffusion occurs when over time moisture enters through rubber brake hoses. The use of hoses made from EPDM materials (Ethlene-Propylene-Diene-Materials) will reduce the amount of diffusion OR use steel braided brake hose with a non-rubber sleeve (usually Teflon) to greatly reduce the diffusion process.
THINGS TO REMEMBER
Brake fluids dry boiling point is more important than wet boiling point when used in a racing brake system.
Passenger cars very rarely will undergo a brake fluid change making the wet boiling point more important.
Racing brake system fluid is changed often and a system with fresh fluid will most likely not contain water.
Because of this, racers should be concerned with the dry boiling point.
Racing fluid exceeds DOT 3, 4, and 5.1 dry boiling point specifications.
Never use silicone based fluids in racing brake systems.
Using racing brake fluid will increase performance of the braking system.
Never reuse fluid. º Never mix types or brands of brake fluid.
Use smaller fluid containers that can be used quicker.
If fluid remains in container be sure to tightly seal and do not store for long periods of time.
Purge system (complete drain) and replace fluid often.
Immediately replace master cylinder reservoir cap following any maintenance.
DOT3 vs DOT4 vs DOT5 - Brake Fluids Explained
________________________________________
What are the differences and what do they mean? Much perhaps a topic I never come across on Honda forums. I'm going to give you a simple idea on what each category of brake fluids mean and which is the one most suitable/applicable for our CL7/9s for road and track work. After all, selecting the correct and most appropriate brake fluid comes hand in hand with how good your brakes work under all situations and circumstances.
Polyglycol Based DOT3 - Color - Amber | One of the most common finds on the market and have a specific for cars designed for the late 80s period. Although compatible with our CL7/9s should you cannot find the required selected grade, this is not the correct specification to be used from factory recommendation guidelines. DOT3 also absorbs moisture the quickest and has the lowest boiling point and should only strictly be for road use.
Polyglycol Based DOT4 - Color - Amber | The benchmark specifications by the majority of car manufacturers, this is also the specific grade to be used with Hondas/Acura cars regardless of models. DOT4 is designed to absorb moisture slower than DOT3 and has a higher boiling point. This is both suitable for road use and track work. While the OEM Honda DOT4 brake fluid is sufficient for weekend track days, meets etc. Using racing specific DOT4 refined brake fluids will increase higher temperature tolerance particularly under hard braking conditions.
Silicone Based DOT5 - Color - Purple | Least common and also the most different from both grades above. DOT5 are primarily designed for cars not equipped with ABS units (Unless otherwise manufacturer specific)and this should not be used unless you're absolutely sure of what you're doing. DOT5 does not absorb moisture and holds the highest boiling point. This brake fluid is not compatible with either categories above and should never be mixed due to its chemical properties.
Always take care when handling brake fluid as this will corrode body paint work in a matter of seconds if contact is made. Should accidental spills or drips happen, immediately flush affected surface area with high spraying water and wipe off area.
Should you choose to switch to a higher category or quality/grade brake fluid, it is strongly recommended that you perform a complete brake fluid flush. Never use a mineral or synthetic based oil ala engine oil or transmission fluid in substitute of specific designed brake fluid. Such incompatibility will cause all rubber components in the brake hydraulic system to swell up and leak.
__________________________________________________________________
2deuce
147
portland, oregon
I didn't know that the red dash light was a warning light of a system failure. I thought it was only a warning that the parking brake was still left on. That red light on my truck is on with the engine running and with the parking brake off. This means one or both systems are in failure mode. I do not see any evidence of leaks. What I need to determine is who stenciled Dot 3 on the underside of the MC access door. The firefighter who operated this truck told me the brakes always worked well. He said that a different driver used it one time and complained that the brakes didn't work and have not worked well since. The truck was disposed of because of this problem. The only mention of brake fluid is on that access door where it says dot 3. Did the military ever convert back to dot 3? If dot 3 was added to dot 5 is the reaction making the brakes fail immediate or gradual?
I think Rusty Stud gives the best solution for a total system failure. I wasn't going to use acetone or any other solvent to clean out the bad fluid. I was afraid of ruining all the seals, but if I need to change them all anyway and rebuild the airpacks, I suppose it is a risk that may be taken and then replace seals that are leaking.
What I think I will try is clean out the MC completely. Then try to suck out fluid from the mail line at the MC. I'm thinking the mixture should be confined to be near the MC and the air packs still have the dot 5 in them and the wheel cylinders as well. If I can't pull fluid out, I'll try disconnecting lines from the MC and blowing them out with the hope the contaminated fluid is confined to be in the MC or close to it. Now if the reaction between the 2 fluids is gradual this is less likely to work because more mixing would have taken place deeper into the system.
I've moved the truck to my forest property because of a lack of space at home so I can't work on it as easily. That manual will be very helpful to prepare(extra thanks to frank8003) and I'll get pictures when I'm out there next time. If anyone sees flaws in my logic or has any thoughts that may be helpful, I will appreciate your input.
frank8003
4,983
There is cases of DOT 5 by the gallon on that auction site now for 96 bucks total delivered.
There is the "one man brake bleeder" at NAPA for about 8 bucks to put on the end of the individual bleeders that work real good with less mess. Rig a power bleeder and use that. Get 7 or 8 clear jars and then you can tell where the DOT 3 got to in the system as you power bleed the system.
An alternative is to just flush it all out with DOT 3 for this year and get the truck on the road. Dot 3 is much more inexpensive. Members this site use DOT 3 and just change it out every two years.
frank8003
4,983
Those are good articles describing the differences and pros and cons of each type of brake fluid. Thanks frank.
I sent you originals in email.
Rustystud keeps so busy He can't empty his SS PM box!
rustystud has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
2deuce
147
portland, oregon
If I can determine that the Dot 3 didn't get far beyond the MC I'll keep it dot 5, but if I have to blow out the entire system I'm going to Dot 3. The problem I remember bleeding a truck in the past was I questioned whether I got all of the air out. Where the truck is now it's level. Here at home I always have a slope to deal with and thought that might be the difficulty in getting the last bit out.
frank8003
4,983
It is just compliance with page two and page three in the attached.
The wheel cylinders are the low points in the system. That is where the water will separate from the DOT 3 and goto.
Purple DOT 5 is better stuff.
I found the motive power bleeder and that NAPA one man check valve thing made it a easy job
Part #: BK 7769089 at NAPA
It will make it into a simple job.
2deuce
147
portland, oregon
I made a power bleeder out of a sprayer once and I'm sure I still have it, but I remember using it with a metal screw IN fill cap. This 1988 deuce has a plastic screw ON cap like a power steering reservoir cap. and it's kind of big. That's part of the problem with having the truck parked 60 miles away from home. I can't go out and check it. I saw an adapter for a power steering reservoir that would work if it fits and stays in the filler. Probably needs to be held in when pressure is applied making this a 2 man operation.
frank8003
4,983
answer here last post, sort of .............
https://www.steelsoldiers.com/showthread.php?72751-Bleeding-brakes-on-a-M109A3-Dual-Circuit-System
much interesting stuff in here
https://www.steelsoldiers.com/showthread.php?82529-Dual-circuit-master-cylinder
So goto the SMI 9 2320 209 14&P to figure F-12 which shows cap and
o-ring. Indicates cap is P/N 2231936.
Google to Part Target and put 2231936 into search which gives
NSN 2590 01 0176 2816 as being P/N 2231936.
None at my normal searches so just put 2231936 and/or the NSN straight into google and there is your new caps for about maybe 10 bucks.
All this tells me it is a GM part number Part Number: 15513988 (2231936).
And this is new caps for your master cylinder so you can rig something before ever going to the truck
https://www.wholesalegmpartsonline....ster-Cylinder-CAP-COVER/2740809/15513988.html
And a picture for the General
but I could be wrong like that one Tuesday, anyhow you get the idea.
2deuce
147
portland, oregon
I went out to the truck yesterday to check on everything after the windstorm we had. I brought a big scringe with me to see if I could pull any of the fluid out. It turns out that the fluid isn't thick. It is a greenish yellow. What I thought were suspended bubbles must have been there from pumping the brakes. The truck also had a used air pack in it and in the tool box there was a bottle of Dot 4. Now I'm beginning to think they changed to Dot 3 when the air pack was changed and the entire system is dot 3 and 4. It may only need a bleeding. I found some records in the truck that said the brakes were not functioning back in 2015. I didn't find anything that said what was done, but the used airpack gives a good hint. If I find Dot 3 at the air packs and wheel cylinders, when I bleed everything, I will be happy with that. I won't forget to post what I find after bleeding, in case anyone is interested, but it could be a while before I get too it. One thing I'm going to do is pour some dot 3 and 5 together in a jar to see what they do, because after everything I've read it's still not entirely clear what happens.
rustystud
2,779
DOT 3 and DOT 5 will separate. If you do have cross contamination between DOT 3 and DOT 5 then you really need to replace "all" the seals. Every wheel cylinder and brake master cylinder and air-pack needs new seals installed.
frank8003
4,983
from 01022013 welldigger post #8
O and simple test for brake fluid is pour some brake fluid into an empty water bottle. Then add some water and shake. If you have dot 5 it will separate out and float on top after a while. If you have dot 3 or 4 then they won't separate since dot 3 and 4 absorb water.
