MKT power converter
Earth
Corinth Vermont
I need to come up with a power converter for my MKT MBUs. I'll have the harness(thanks Mike) but I will still need to convert 110 to 24v. I don't see a need for the slave cable stuff as I plan to run a quite little honda gen set if no shore power is available. Ideas appreciated.
Thanks,
Tom
frodobaggins
Ruston, La
How much amp draw do they need ?
Just get an appropriate sized transformer, and a rectifier. Add a fuse and some connectors and you're done :)
m109guy
27
ON
275 watts maximum per MBU, with a total of 4 in the kitchen unit. What I need to do is make 120vac to 24vdc
Or even better, just buy an MKT power inverter and skip trying to jerry-rig something.
Did you try posting a wanted ad for a unit? They are rare, but not impossible to find ;)
Earth
Corinth Vermont
I would love to buy one. I've checked around and can't find one, so I'm starting to think about other ways to get it done. But I did just post a wanted add in the classified.
Avn-Tech
31
California City, Ca
Earth,
I have two MKT's for sale in CA, both have the converters, MBU units, cabnets, ect in them. I would not mind parting one or both out, but would need to sell enough parts to get a return on my investment.
Laterrrrr
Avn-Tech
cbvet
20
Northwest (Knox) Indiana
If you can find a deal on two 120v to 12v converters, you can connect their output in series to get 24 volt. Just like connecting two batteries in series.
Just make sure the converters don't touch each other.
I use old RV converters in series to test my fuel-burning heaters. One is a 30 amp & the other is 40 amp, so hooked in series I get 24vdc with 30 amps.
267
Augusta, New Jersey
V3 Power Converters
Using the "stock" power converter in the MKT is the way to go. Makes the trailer so much nicer and easier to use. I snagged a couple V3's and still have a few left. They are brand new in the box. PM me if interested. So nice to have the corrrect equipment for the trailer. Units were really nicely made by Teleflex.
John
267
Augusta, New Jersey
John, No need for the attitude, I was just bringing it to your attention, should you expect a PM from the OP.
Jonothan,
Not sure what this is all about, but you posted the comment? I was just looking at an old thread? If you would like to threaten me, next time maybe do it in a private manner, via PM. Does this kind of thing make you feel better?
John
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
Calm down guys or I'll close the whole thing down!!!!
John, I don't think Jonathan meant what he said in any kind of negative way. The OP, if he is still subscribed to the thread will get a notification that the thread has been added to...I think he was just pointing out that you might get a PM from the OP letting you know that this thread was pretty old.
