modified trailer
maxtor
California
Prices of military trailers are very reasonable. Has anyone purchased two m116a3 trailers and took the axles out to make one two axle trailer?
harleyhouse
30
Oakmont, Pennsylvania
235-85-16 tires are a good height for a deck over trailer .
The only issue would be lack of articulation with two sets of fixed springs.
I would build something like this.
John Galt
Fort Worth, TX
It should be possible especially if you were using a tandem axle spring set up. The issue will be how to get working brakes and that doing a spring under the axle may run into clearance issues with the high spot in the center of the axle.
