- 621
- 1,588
- 93
- San Diego, CA
I did a lot of cutting and dissecting on the front of this currently trailer mounted habitat that will go on my M1083A1. Water had gotten in there and caused a lot of rust and aluminum rot from wet fiberglass. I needed to modify the front anyway so all of that had to go. I have completed the cutting and reused some of the pieces I cut out for chamfering the front edge by one foot. I will be using one and three quarters square tube to fill it back in with structure then reskining it and using polyiso foam insulation. I welded in supports prior to cutting so that nothing moved. I will be removing a couple of the side windows to put larger lower windows in and repositioning those side windows into the openings I'm making. Can you guess the reason for the chamfer? This area will no longer be used for heaters or air conditioners as I have removed those and scrapped the air conditioner. Instead it will be a bunk bed nook for my daughter.
