corelokt
- 2
- 16
- Duffield, VA. (East of nowhere).
1. Where are the battery terminals located on a cucv? Are they post or screw, top or front, positive on the left or right?
2. What glow plugs to put in to make it a manual button glow plug system like in the stickies?, my tractor runs like this, and it's fine for me.
3. I'd like to have one alternator charge both batteries for starting, and run the other to a deep cycle battery and a power inverter for 110v power. Can I do this and keep the starter 24v?, or is it better to find a high torque 12v starter?
4. I'm thinking I'll mount both an engine and transmission cooler under the hood, with flexible lines and louvers to feed them air, thoughts?
5. Anyone ever mounted a hydraulic pump on a 6.2? I'd like to avoid splicing into my power steering for my hydraulic winch.
6. If I were to run tall tires with the stock axle gears, towing would certainly suffer. What's the cheapest way into an under drive?
7. In regards to putting in a turbo, it would have to be used, anything you know that I should?
8. I will have up to four persons in the vehicle, infrequently, but will also be using it to haul both normal family stuff, and things like deer to the butchers, firewood, rocks, stuff found on the side of the road, animal feed, and so on. Anyone have any interior idea's, or input?
9. I will want a stereo, tell me what you've done regarding speakers, I'd like to avoid cutting the door panels.
10. What other mods' have been done that are worthwhile for my type of use?
Sincerely, Giles.
Sincerely, Giles.
