More speed out of M1008
84cucv1ton
New Jersey
i found a few things so far. here they are. whats left of a early 90s dodge. was a ctd. guy bought it for the motor. 5 speed 205 still there. dont know real miles on it but its a lot.
98 4l80e from a k2500. trans nothing else no wiring or computer.
4" lift kit. 35" tires. i dont want to go high with it so i can use the bed. truck tows too. really nice truck. not going to take it offroad.
found a 84 700r4 for a decent price. from what i read. 84 is not a very good year.
thinking a lift would be the cheapest option. overdrive down the road. really like the idea of a 5 speed
any ideas or thoughts.. thanks [thumbzup]
Kaiser67M715
26
NH
1, Dodge 5 speed notorious for 5th gear nut backing off( loss of fifth, occasionally will lose ability to shift all gears, especially if you were shifting in/out of fifth when nut fell off.
2. 4l80 is not bad, just requires a computer and speed sensors, which is sometimes a hassle
3. 700 not bad, you can beef it up when rebuilding, but one can easily fry the tranny in a few miles if TV cable is malfunctioning/ misadjusted
Just a little input
84cucv1ton
New Jersey
i like the 5 speed. he no idea on real miles on the truck and he wants 1000. seems like a lot. very expensive to rebuild.
4l80e very expensive to rebuild. computer is a lot as well. going to pass on this.
700r4 it is . way cheaper. have a tv bracket now. can a 700 be rebuilt pretty easy like a th400_
for now small lift and a set of 35in tires wins.. found a set of bfgs. need some lift springs. do my own shackle flip in the rear. this is the way to go for now. summer time ill get a 700r4 in there.
thanks for the input
Kaiser67M715
26
NH
somehwere, and maybe someone else here knows, but there was a chart that gave estimates of speed, throttle, and shift points to make sure the TV cable is adjusted right....well it was more of a guidance chart, but would probably be helpful none the less
1,807
Westy has 3.08 gears. I'll run mine all day long at 65 but it has 4.10 gears. SM465 is on the horizon for me, it's actually good for a couple of more MPH since it is 100% locked up.
JUNKYARDJOHN
somerset ky
700r4s are great transmissions. Although inheredly weak & very expensive to rebuild in there stock form. They can be built to be bulletproof.. but that is very very expensive (think thousands of $) If you know someone or have the abuility to rebuild it yourself it will save you a lot but your still talking about a whole bunch of $ just for the parts. (Not at all like a t-400 dollar wise) There are tranny. experts on this site that will no doubt step in & give you some great advice. good luck... John
