more speed?
Josh
12
Portland, Oregon
A member here makes a overdrive kit to get more speed, you can put on bigger tires. Overson makes new gears for the rockwells that arnt cheap. Or you can put a new engine in that revs higher.
Alexl2590
clifton,nj
it sounds like i should leave it alown is there a governor it seams like it starvs a lil on hils and there not that big
gimpyrobb
dumpsterlandingfromorbit!
27,787
778
Cincy Ohio
Yeah, the 6.71 R&P really murders any speed you can get. The OD gear set is the best(cheapest) way to go for speed.
gimpyrobb
27,787
778
Cincy Ohio
Some trucks come factory with the fuel way down. You can bump it a little till you get a slight smoke from the stack while driving. Any more and you'll want a pyro.
Josh
12
Portland, Oregon
if i turn the fule up a little bit you think i can get a steddy 55mph out of it if i can get that ill be happy
Definitely install a Pyro. 55 on the flats is easily doable. I have my fuel turned up as safely as I can. My truck will slow down to about 40mph on a 6% grade. Before I did the fuel it was 25mph up the same hill.
Alexl2590
clifton,nj
i know this sounds dum but what is a pyro and does what it do
m816
Chatham, NJ
I have apyro on my M54a2. I also have an overdrive trans in it. The truck would go almost 68 mph. before I toasted the engine. We rebuilt the engine put a new Ip on it and added the pyro. The pyro lets you know when you are getting dangerously close to heating up the pistons. It sure chages your driving habits. She is a dog now, but it is all rebuilt and will probably out last me. I'm back to just over fifty mph flat out. No smoke but no top end. At this age I should be content to just getting there rather than gong for the pole position at the track.
73m819
328
gainesville, ga.
The FIRST thing I would do is MAKE SURE my FUEL FILTERS are CLEAN (close to NEW, if not NEW), any good running and well maintained deuce without being tricked should run 50 or a bit more, heck when I drove Jims LOADED deuce to Wi, it did 50+ except STEEP grades, it was not turned up and on 900s and a VERY well maintained deuce.
If people keep there filters close to NEW and NOT wait till thay are about 100% plugged to change, and keep the TOP END adjusted correctly, thay would be AMASED by the performance of there deuce
fuzzytoaster
3,665
Fort Worth, Texas
Pics!! :drool:
