This is a GL buy. I have two problems. First Getting the combination to work (L50 4x - R25 3x - L50 2x). second is there any way of using hanging folders? They just don't seem to fit. Thanks Hey its Military surplus. Great cabinets
Can't quite see the lock, but the combination change suggested above may work. You know you probably have to turn it back to the right to zero after dialing the combination to lift the locking pin, right? At least on mine it is that way: First number, second number, third number, back to zero, where it will catch and lock just past zero as it pulls up the locking bar.
These things are a PITA to work with, and a PITA to unlock (hate opening mine!) and offer limited security, but if you have it already opened, you are one gigantic step ahead of the game (mine was locked when I got it, and I had to drill it and put in a new lock).
See if you can find out what lock you have as several were used in those cabinets. If it is the same as mine, I probably can get you through getting it locked.
BTW, those locks are standardized, and you can replace it with a new one, digital if you want. Many locksmiths, if friendly, will give you a lock for free, as there is no market for them anymore.
Oh, and the cabinet doesn't really offer much security. There is a device (basically a computer driven combination dialer, that will open any of them in a maximum of 24 hours--it just dials every possible combination until it unlocks. THen a small display reads the combination that worked!
![Wink :wink: :wink:](https://www.steelsoldiers.com/images/smilies/icon_wink.gif)
