Motive Bleeder Adapter?
1,818
If it does fit it will be a royal pain in the keester to work with. You would either have to feed that little hose up from the bottom through that support crossmember or unhook the hose every time you install it. I use a brass 1/8NPT nipple 4" in length with a hose or quick coupler attached and screw it right into the factory cap. I should also point out that there are 2 different size caps for deuce masters depending on which casting you have.
SixSpeed
Banned
1,107
Tampa, Florida
Ah, well if there are two sizes then forget it. Even if one of the MC's cap is the same as that adapter, it will NOT be the one I have. That is pretty much guaranteed, haha.
The little breather on the cap is 1/8 NPT? I suppose it would be easy enough to remove the breather and install a tube to the bleeder.
Tinwoodsman
76
Comfort, Texas
Having just compared the caps on my deuce and M101A2, I am certain it will not fit the deuce M.C. That cap is larger than the trailer cap.
