TCD
- 7
- 18
- Mound.House, NV
Howdy,
This is a slow project that I will update as significant milestones are met.
I am mounting a Air Force Craig box (rough external dimensions are 8'w x 12'l x 87"h) on the bed of my 923-a2 as the base for a camper suitable for the South Western United States. Yes it is tall at slightly over 12 feet however I have friends with similar rigs who find the height manageable.
The Craig box is 100% aluminum and the bed of the truck settles less than an one inch when the box is set on it.
I started by removing the bed sides and setting the box on the bed for the first fit.
![Truck-Box-Sideview-org-a.jpg Truck-Box-Sideview-org-a.jpg](https://www.steelsoldiers.com/data/attachments/436/436446-2bea0ac9f9c9a6843bab7a7e04243645.jpg)
Because of the permanent front section of the bed the box just fits flush with the back of the bed. At first I thought I would use the front space for storage of propane bottles etc.
![Truck-Box-Sideview-org-c.jpg Truck-Box-Sideview-org-c.jpg](https://www.steelsoldiers.com/data/attachments/436/436447-fbb339026dde2507647e9fa55b8e0016.jpg)
![923-Bed-before-a.jpg 923-Bed-before-a.jpg](https://www.steelsoldiers.com/data/attachments/436/436448-24b7574d5ba1bbe1f8ab909d09dbd2aa.jpg)
However I decided that I wanted to move the box forward because a) I wanted a back deck space, b) I wanted to keep the functioning of the tailgate and c) I felt the esthetics's and balance of the load looked better with the box forward.
So I cut off the front upper part of the bed which was not a trivial task!
![923-Bed-after-a.jpg 923-Bed-after-a.jpg](https://www.steelsoldiers.com/data/attachments/436/436449-b767deb890260d4c151b549d74bc8698.jpg)
Here is the box on the next test fitting:
![Truck-Box-Sideview-new-a.jpg Truck-Box-Sideview-new-a.jpg](https://www.steelsoldiers.com/data/attachments/436/436450-12e596ae0992f3d4f86b9acbab36eea5.jpg)
![Truck-Box-Sideview-new-b.jpg Truck-Box-Sideview-new-b.jpg](https://www.steelsoldiers.com/data/attachments/436/436451-5499f80dd5c6cbaf1c3ea774dda37c0b.jpg)
![Truck-Box-Sideview-new-c.jpg Truck-Box-Sideview-new-c.jpg](https://www.steelsoldiers.com/data/attachments/436/436452-0be23ff33753a2bc5603fd477035b585.jpg)
![Truck-Box-Sideview-new-d.jpg Truck-Box-Sideview-new-d.jpg](https://www.steelsoldiers.com/data/attachments/436/436453-f7241ff2d1673ea03541988eb89b64c9.jpg)
![Truck-Box-Sideview-new-e.jpg Truck-Box-Sideview-new-e.jpg](https://www.steelsoldiers.com/data/attachments/436/436454-2464502c10e1d68edc464feb3e4bb5e6.jpg)
Personally I like this fit much better!
Next I will finish the trim job on the front of the bed and start making the box to bed mounts. I am going to do something similar to the bed to frame mount of the 923 and the shop box mount on the Deuce so there is less flex stress on the box and hopefully I will not change the flex built into the bed by the original design.
I also did the tailgate mod posted by “TwistedOaks” at http://www.steelsoldiers.com/showth...e-lift-assist-using-spring-hinges-with-photos! This was an easy and great mod! Thanks TwistedOaks!
I am also spending a lot of time thinking about a gangway design that will allow my old Golden Retriever easy in/out access as he and I need to avoid steep stairs...
All thought and comments Greatly Appreciated!
Happy Tails,
tom n tyler
Happy Tails,
tom n tyler
