bigbee
- 4
- 18
For all you people that have the composite turn signal/black out lights on your M37s-how did you modify the brackets to fit the lights?
For the front:
I found that the front marker light brackets have the wire hole too high to fit the wires through and am not happy with cutting the hole bigger. Is there another way to do these brackets or is anyone making a replacement bracket that is high enough and has the wire hole in the right place?
For the rear:
Trial fitting shows the composite light unit to be taller than the stock round unit. Immediate solution seems to be to fab an adapter plate to mount to the stock taillight bracket and mount the taillight assemblies to that. Again-is there another way to do it or is someone making a replacement bracket that has the allowances for the extra height?
This is going on the truck I'm selling, but will need the same on the project truck in a few months.
For the front:
For the rear:
