Mounting options?
warcow105
Lincoln Park, NJ
Does anyone else have the same mental issue as me when it comes to drilling holes in their truck? If this was someone else's project truck before I got it and there were holes everywhere it wouldn't bother me, but this one is in nice shape and I can't bring myself to do it.
What ways have you mounted lighting, reverse cameras, and switch panels using pre-existing holes?
Mike
NDT
6,142
Camp Wood/LC, TX
Fast forward 70 years and the collectors of the future will be cussing all the holes you drilled like present collectors do with the mods that were done to the WWII Jeeps when they were surplused. Or not.
warcow105
Lincoln Park, NJ
Maybe that's why I have a problem with it. I have modified many other vehicles, but this one has been god knows where during god knows what and it is in great shape, but now I'M going to be the one to shoot it full of holes?? It's like a vet coming back without injury and popping him in the foot with a .22 lol.
Mike
98G
Former SSG
4,170
I have not drilled a single hole in mine. Any modifications I do use existing holes.
(Ammo can center console, license plate, etc.)
My philosophy is to leave the truck unmolested and make my mods fit the truck instead of making the truck fit the mods.
Your truck. Your call.
JoeJrTheBarber
19
Chicago, IL
I am kinda with the others as its your truck and do with it as you please.
I don't like to drill holes everywhere, but to look at things abit different and maybe move things around or swap locations for things (if that makes sense).
As in I removed the stock reflectors on the back of the truck and mounted my reverse lights. And notched a space for my back up camera on my "filler" panel that came with my
body lift. I also plan to use smooth cap head bolts in various sizes to fill in all the un-used holes around the truck before I paint it.
Your truck, do what you feel fit to / with it...
BLK HMMWV
453
Pasadena California
Forgive me but I don't understand why it matters. If you want to install stuff normally not found on them what difference does it make ?
it's your truck . If your goal is to keep it all original then you will find a hole to fit the part. If your modifying it to fit your needs your going to have to drill a hole to hold the new part.
warcow105
Lincoln Park, NJ
Hence my question as to what others have done to mount things without drilling more holes. If I can get away with mounting things in a way that I can remove them later without leaving holes everywhere then that's what I will do.
Mike
Wire Fox
159
Indianapolis, Indiana
Take to making sheet metal brackets. You can mount this fabricated plate so that it matches up to existing holes and then drill like mad on that bracket you made. Just take a look at the radio rack, speaker mounting plates, and made other items throughout... It's relatively common for them to work that way. Your only major holes to drill will likely be for passing new cable assemblies inside the cab.
Sent from my Nokia 6.1 using Tapatalk
90Jimmy
Southern Illinois
Mike... me too man!!! It's hard to make those modifications. I struggle, but recently just took a deep breath and said do it.... enjoy my truck. In the past I've kept vehicles just perfect....perfect for the next guy. Older and wiser now. Enjoy it, make it mine. The little "damage' a respectful, responsible dude makes to his truck probably won't alter its operational capabilities or value for "the next guy" anyway. My humble opinion.
Do what you do, post pics so I can dig it and maybe do the same.
JEB
131
Colbert, WA
I've noticed a popular vendor has a "no drill"
license plate attachment that uses existing holes.
If there are other similar holes (or bolts that could be removed, an item inserted and the bolts relaced) that would be one way to add back up lights and camera.
A piece of aluminium and a sheet metal brake might be all you need to make a functional attachment point. Some touch up paint in body color or flat black and the piece would be unnoticeable to most.
You'd have to go a long way before you could modify (or wreck) a HMMWV to the extent many Jeeps have been. A friend rebuilt CJs, he said half the battle was removing "improvements" done by past owners.
DatGuyC
21
Essex, Maryland
I don't like drilling holes either and use existing holes when possible. I just feel that if I ever change my mind on the placement of something I will still have a permanent hole in that location. For my reverse lights there are already holes on each side near the bottom of the fenders so I just put a bolt through those for the light bracket, works great.
TOBASH
3,244
Brooklyn, NY
You can brass plate the whole truck and place it next to your kids first pair of shoes, or you can use it and drive it like you stole it and drill holes where you need.
Initially, I hate modifying anything, like I will somehow annoy the gods, but in actuality, does it really matter.
Someone here answered a similar question maybe a year ago by saying that the military mechanics did whatever they needed to do to make these machines fit any job they were needed to perform. Essentially they would hack things up as necessary.
That begs the question; "why are we so sentimental now when the military didn't care back then?"
Find a balance that works for you. It's called "restification" or restoration with modification.
Avoid adding flashing disco balls while performing mods you find important.
Just enjoy the freakin' vehicle and don't worry about it. Just don't drill new holes into wires and fuel lines and hinges and such.
MHO
T
DatGuyC
21
Essex, Maryland
MHO
T
I think it comes down to how it is acquired. We spent our hard earned cash on these trucks and don't want to mess it up because we will have to pay to fix it. Guys at the motor pool don't care if they drill holes and chop stuff off, its not their truck and uncle sam will pay to fix it if need be.
Migginsbros
6,236
Berlin-Germany
We don´t like extra holes especially in the roof. The pre owner (civil protection) of our recently purchased MAN Kat1 5ton mil glw doesn´t matter how to get some convoy light and a siren fixed.:(
Each light fixed thru 2 holes + one for the cable and the siren damaged the roof with 3 hole,too.
We want to get rid off these stuff, close the holes and find a better set up for one rotating light, perhaps on an extension, so you can see it from all sides.
Migginsbros
:tank: More pic´s from our MV see this month poll https://www.steelsoldiers.com/showt...diers-MV-of-the-month-2018-December-VOTE-HERE! :driver:
Stonewall
Peoria, IL
My way of looking at it is you are doing one of two things to your MV. You are either keeping it 100% original, with all correct military parts and the like or not. If not, then it seem to make no difference if you add some extra holes or add modification. I like the idea of keeping the "look" of the original, but making modification or additions that enhance the overall look.
Retiredwarhorses
4,051
Brentwood, Calif
I have no issue drilling holes to install MWO’s and military issue mods. Other then that, I hate to drill holes in the body.
one example I don’t like is the offset antenna mounts....it’s a personal thing.
warcow105
Lincoln Park, NJ
I feel like I just want to keep it as close to original as possible, while still adding a few things that I want. I have no plans on getting rid of the truck, but in the future if I do and the new owner wants it all original then I'm sure he will appreciate the extra care I took mounting things.
I took the advice of JEB and ran to Home Depot for some aluminum angle and square tube. I'm going to scout around for some existing holes I can span to give me a surface I don't mind drilling.
What other interesting things have you guys done for stuff like a light bar above the windshield? I saw a nice one for sale but don't really feel like dropping $600 on it.
Oh, and I'm currently set up as a 2 door with future plans on the 4 door conversion, but till then are there any covers to the cargo area that look more like an SUV/wagon body? I'm just not a fan of that troop carrier one that sticks up so high.
Mike
BLK HMMWV
453
Pasadena California
Radio trays are fairly cheap. mount as much stuff to one of them as you want. .The next guy can source a new radio tray or buy two of them .
Keep one original then get as creative as you want with the other.
Same thing with the light bar. buy a IBES TEK one and use the brackets that come with them for the HMMWV or buy what you want and mod your truck.
