Mounts under front bumper
rcb
pittsburgh, pa.
Greetings !!! I am puzzled, I've seen on some M880's (2) mounts installed
under the front bumper that resemble shackle mounts, plow mount, etc.
They are on one of my M880's and I installed shackles on them, but I
was curious what they were originally intended for. Anyone know ???
Jeepsinker
455
Dry Creek, Louisiana
Yeah I have a set of these that came in the side box on my wrecker. They have 4 bolts holding each one on? Reason I ask is because the ones I have are labeled as such.
jonesal
Mission Specialist
69
Brookings, SD
Can anyone post pictures of them mounted to the vehicle? I would appreciate it.
Thanks,
Al Jones
zebedee
conceptualizer at large
724
Central NY
I do not know if they are normally left on the vehicle - my M816 came with a bunch of those, mixed in with all the other tow bar feet, for attaching by the H8's at the motor pool or scene of wreck.
However, if they are not part of the wrecker kit and do in fact live with the 880, then that's more ballast I don't need to carry and can get rid of!!!
1,808
What I'm about to say is pure speculation. While they do work for towing and the mount is plenty sturdy, the way it's mounted is not robust at all. I'd bet dinner that somewhere in a PM Magazine or other, there is a directive to remove them after tow. Any use as a recovery tool could be fatal and I'll guarandamtee the Gov't figured that out.
jonesal
Mission Specialist
69
Brookings, SD
OK, that's all fine, but we'd still like to see some pictures of the setup. I think it would be useful to have the setup documented on SS. I searched for awhile on SS and the net and could not find any pictures.
Thanks,
Al Jones
jonesal
Mission Specialist
69
Brookings, SD
Lots of pics of the UNmounted bracket and plate. Maddawg, that second picture is rough - do you have a higher res view - I can't see what's going on? The cover page of the manual in post No. 14 is not for a M880 - I'm confused. The page from the TM shows it mounted as a cartoon. I'm still looking for actual pictures of actual mounted brackets and plates.
I've searched the site and can NOT find any pictures of them mounted. I was hoping doghead would jump in and embarrass me with his astounding search skills.
Al Jones
with lonely M880 tow brackets and plates...
M543A2
11
Warsaw, Indiana
Two of ours have had heavy angle irons with holes in the end mounted in that location. They angle inward a bit. I wondered if it was some kind of adaptation for tow bar?
busbart
france
Well, I noticed at my other frames, that at all frames I have, there were already all the holes predrilled in that location, which makes me wonder, if those brackets were to be carried by wreckers only, and to be mounted prior the towing/recovery and then removed, or if they were a modification of some sort?
