I need a facepalm smiley - I didn't even think about eBay. Thanks for the reminder!Search ebay for "mrap adapter plates" This is where I got mine, identical to the ones mentioned elsewhere here, as far as I could tell.
I bought the bolts from Tri-State Fasteners.
As long as they have the 11" center hole then Yes. There are a couple of Mraps that use wheels with the smaller 5 ton spacing so just beware of those.Im on my phone, so cant do a thorough search, so if this has been covered I apologize: do all MRAP wheels have the same ~11" diameter opening? I.e. will the same 10 hole bolt-on adapter work for any of the wheels?
Cheers aaron, appreciate the response. Is the difference between the two substantial? E.g. the smaller diameter is 7" and the larger 11"?As long as they have the 11" center hole then Yes. There are a couple of Mraps that use wheels with the smaller 5 ton spacing so just beware of those.
