Swamp Donkey is using the RG-31 type IIRC, I like those and I like the MAXXPRO style...I have a few mrap bumpers left. The ones with the center hole for winch pass thru.
Not sure if that is quite the style I was looking for. Have a frontal shot? Looks like on of the RG31 variations.... Definitely different from SD's.
That's what I hear...you better be lit if you're going to compete with him...Swamp and I are going to try to make the space station see us at the rally lol.
Looks like all my HET kits are spoken for. SD got one.View attachment 633988
I want one of your light kit for rear.
Judging from the size, you'd need one...That would work good on hemtt
Dont imagine you get replacement bulbs at autozone....I have a few of them. Draws around 45 amps at 27 volts. View attachment 633994View attachment 633993
One could get one heck of a sun tan standing within a few hundred feet of this monster. Is the light adjustable and does it have a flicker mode? If so, what is the flicker rate in Hz? I have a shoulder mounted one that runs for 20-minutes off a tactical vest and recharges on the standard NATO plug. I would not mind having one of these.I have a few of them. Draws around 45 amps at 27 volts. View attachment 633994View attachment 633993
