MRAP Electrical Outlet Box Identification
fuzzytoaster
3,122
Fort Worth, Texas
I'm assuming that MRAPs go under armor..anyways. I picked up this dual output 7-pin & 12-pin connector box off an RG33L model MRAP and am curious to it's purpose and capabilities. Finding a TM that answers this is either behind a paywall or needs DoD access (TM 9-2355-320-10). Any input would be great and hopefully this unit can convert 24v to 12/24v output. No exterior markings were noted on the box itself.
NDT
6,486
Camp Wood/LC, TX
I that's from a Caiman then it's the usual FMTV dual 12V /24V circuitry, each socket being supplied independently from the in-cab relay/circuit breaker panel.
ke5eua
41
Baton Rouge (Central), LA
Yep dual, 12v semi on left , standard military on right. Neat that is has the self resetting breakers right there.
If you don't have a need shoot me a pm, I'll take it off your hands for you.
fuzzytoaster
3,122
Fort Worth, Texas
Is is.
It couldn't be that convenient
My thoughts too but one can be hopeful.
I've got a few.
ke5eua
41
Fuzzy set one on the 818 and I'll give you some green paper for it when I come get the truck.
I need to put a 12v 7 way on it and that would help start the project.
