MRAP Rims.
79f250guy
Macedon NY
Wondering if anyone on here has ever run regular truck tires on the 20” steel mrap rims. Looking at putting a set on my super duty with hub adapters obviously but not sure if I can run a standard E load range 37 on heavy duty rim. I figured if anyone would know it would be this group.
Matt
simp5782
Feo, Fuerte y Formal
9,367
Mason, TN
Matt
You can run any tire you want on a 20in wheel as long as the tire is supposed to be on a 10in wide wheel. Most IROKs and interco stuff in say 36x13.5x20 are for a 10in wide wheel.
The MAXXpro plus had an issue blowing the 395 XZLs in Iraq, they ordered tires from interco for the extra weight, they were on 20in wheels they blew as well. They then set the large shipment of tires on fire. The maxxpro plus now uses 12R20s on the rear in dual for the fix
