MilSpec78
- 3
- 0
- Saratoga Springs, Utah
Hi guys,
I am having trouble locating torque and other specs for wheels I recently purchased from GL. I believe they are from the Husky model MRAP. I was hoping someone here can help.
I need to replace the air valve on one of the wheels and I need the following information before I begin:
What are the torque specs for the wheel rim nuts that hold the two rim halves together?
Are these nuts self locking and should they be replaced?
Is there a part number or a civilian substitute I can use to replace the air valve?
Should the O-ring be replaced and does it use a standard O-ring for a 20" rim?
It would be great if there is a TM publicly available for MRAPs that would provide this information. Otherwise, I was hoping someone could assist me with this information.
Thank you!
Thank you!
