MRP Wheels on the LMTV
juanprado
2,829
Metairie/La (N'awlins)
Interesting as I would have suspected the camian wheel is the only one with the same pattern and hub. It is my understanding the only difference is the run flat not used on the fmtv
freecr
Rochester/MN
Salvator, Can't you just remove the correct hardware from the steel wheel or aluminum to thick to use it? Where did you get the longer lug studs from?
salvator182
Charles Town, WV
That's what I was trying to avoid. I can pull the valve stems off the old rims but I was just attempting to avoid tearing 8 wheels apart then remounting them.
The larger valve stems came on the wheels when I picked them up from uncle sam.
