Still looking for insight, trucks are selling next month
I'm not any sort of expert but tburke49760 hit your answer on the money with actual inches. He reports a bed height of just less than 5 feet off the ground will be as low as your going to get. Do know you can't swap to smaller tires to get lower height though and still be usable, cause there is not a Ring and Pinion Gear set for the axles made to bring you back a total ratio that will allow for normal road speeds.
LMTV means
LIGHT MEDIUM Tactical Vehicle (4x4).
MTV is only
Medium Tactical Vehicle (6x6). There was no
HTV built around this trucks base design.
IMHO...... Since bed is that high normal ramps won't do. You'll have to go about it by towing a heavy ramp trailer behind you to drive things on to get them on/off or by having a large loading dock/earthen berm built at each load and unload site. Then again though, if you do get them up there; except the 6x6, IMHO she'll be way too top heavy with a
large piece of equipment up there. (Example couple B series Kubota's might be ok, Regular L series maybe, but larger L??? Then the M series, welll... dont think so), 6x6 may still give you some white knuckles though.
That being said....... for the money they are not a bad piece of equipment when it comes to how much hours is on the engine. IMHO if you go this route consider a 6x6 and put a proper Goose neck or 5thwheel hitch- Modify trailer to mount to said hitch mounted up so unusually high.... AND TOW a low boy type trailer with your equipment on it. (or buy surplus military 5th wheel trailer if such a low military boy trailer exist. Don't have the knowledge to say such an animal exist or not ).
BUTTTT!!!!. YOU WON'T GET PAST 50ish MPH when loaded. And not past 55 unloaded!!!.
give us more details on what you want to put on her bed? What tractors models and/or Backhoes, What implements would be attached? hay roles? If so what size and weights? Give us more detail about terrain. How much hill and dale. Is there Any side slopes? ....... are you thinking highway between farms with slow moving vehicle triangle, or ??? Or you thinking offroad only?
as far as I've read on it thus far.. seems PTO can be added but only used when stationary. but don't quote me on that.
Again that is just IMHO. While not real new to similar trucks am rather new to the LMTV and MTV's.
