mtv wont hold fuel pressure.
m35 adam
37865 seymour TN
Hi, just picked up a mtv. 3116 cat. it cranks and will kind of start after pumping the hand primer. Then I have to pump the hand primer again. I don't see any leaks in the system but seems like air is getting in some how. Any thoughts? Thanks, adam
Floridianson
2,502
Interlachen Fl.
As Will said check that rubber. Are you cracking the bleed screw on the secondary filter to remove the air after filter change or are you getting air in the system after just running?
