MTVR situation with VOLTAGE
nico87
Los Angeles, Calif.
Hello, We are having some voltage issues on the voltage gauge that has kept spinning up and down and we have seen some smoke coming from this thick and thinblack cables that were loose and disconnected from their bolts that probably runned loose after driving. These cables are under the ECM, attached to a bolt and this black component that was extremely hot, probably because was not able to discharge properly. This image is a reference found online where these cables are visible. Can someone send me some images for proper connections and locations of these connections and please tell me what component is this in case I need to replace it as I might have fried it? Screenshot 2024-08-24 135601-0-2.png
nico87
Los Angeles, Calif.
I have been looking at manuals but I seem to not finding it on the catterpillar service engine manual neither on the trainee MTVR guide. Do someone has a technician repair manual for the MTVR?
IridiumRed
39
NW MO, north of KC
MTVR military manuals werent printed for the most part, instead was software loaded onto maintenance laptops. Basically all of it is still classified. I hear there are copies out there in the wild, but not easy to come by, not going to find copies online, there are dire warnings all over that stuff in regards to unauthorized possession / copying / distribution (from what i understand).
Can help u a bit w your issue. The terminal youve indicated is the "hot" (positive) terminal on starter. It provides the power to spin the starter when the switch/solenoid is activated. Its fed by a big wire (4/0) from the battery switch behind cab (which itself gets power from the battery). This wire comes up from the bottom of the starter. The good sized vertical wire coming off that post, w the silver acket, that goes to the alternator. As the alt runs and provides charging power, it goes through this line, and since it shares a stud on the starter, the power can flow back to the battery w the big wire on bottom, charging battery.
If i were you, id take that connection loose, clean it lightly (knock off any corrosion), then reassemble snugly (dont go crazy w getting it tight, and use a backing wrench on the nut closest to the solenoid so your torque goes to loosening or tightening nut, not trying to spin the threads in their housing, possiblydamaging something)
Theres a lot of power flowing through this, some looseness / corrosion might build heat from extra resistance. Fixing that might just fix issue. If still some issues, might not hurt to look atthat big wire from starter to battswitch, on my truck it had gotten hot at some point, burned some insulation on it (theres a similar sized wire that acts as ground going to very front of starter, about 8 inches farther forward, that had similar damage on my truck). My truck the electrical system was acting fine, but then it decided it didnt want yo start one day (crank but no start), think its bad ecm, but im right in the middle of going through and cleaning up wiring on mine... cleaning connections, checking for loose / damaged wires. . Hence why all of this is so fresh in my mind :)
Oh! And before putting any wrenches to this have batt switch turned off and for good measure personally i pull ground batt cable.
Also, if u ended up having to replace starter or starter solenoid, make sure to carefully mark all the wires, theres a bunch right there, and theres some of these that could cause big problems if hooked up wfong! Like getting + / - swapped. Or have it not work. Personally i use a bunch of small colored zipties
Anyways. Those are the big pieces i can think of right now. Good luck :)
nico87
Los Angeles, Calif.
Thank you for your response! Appreciated. It is very difficult to find wiring schematics so we hope the original settings of the big positive and negative cables as well the thinner cables was done correctly when we got the MTVR, but it seems the starter was remanufactured as well and re-mounted in early 2000s. So it seems the negative cables from the back of the starter where off, maybe because of a bolt missing due to vibration. Definitely many cables where loose, and seems that loose cables might be the cause of smoke and overheating and faulty voltage in the dashboard gauge. This has probably caused the entire starter motor to overheat and eventually fail, we are rebuilding the failed starter motor but it will take a while to get a machining shop to have the time to do it. However we have removed the original starter motor and replaced with a new- remanufactured starter from DELCO,awe have noticed some grinding in the original teeth of the starter motor against the flying wheel of the one we have removed. The connections of the cable have been executed correctly and it seems that not it starts right away but a very grinding noise is coming from the unit when the transmission is on N (neutral), possibly is the flywheel not aligning correctly with the starter, we are troubleshooting in the next few days. At least we where able to move the MTVR on a more long-term position so we can perform more in-dept longer terms repairs and mods.
IridiumRed
39
NW MO, north of KC
I cant speak directly to the grinding issues, but first thought would be misalignment of some kind. Maybe (and this is just a wild maybe here), loosening the bolts that hold starter on and wiggling it around a little might let it find slightly different position? Shot in the dark, but doesn't cost anything but a little time. If you have starter off again, wouldn't hurt to look in hole, look at teeth on ring gear, make sure they look ok / not all chewed up.
I haven't pulled one of these starters, so i'm just guessing here, but maybe starter is too deep in hole, maybe slightly shimming it out (forward) would help? I'd take it easy, do like .... 1/16" something small (and shim all the bolts holding it on equal amount, try to keep things parallel). But if you had a tiny interference issue could make a ton of noise, only take small change to make big difference. Have no idea if this is actually good idea, just throwing it out there...
If you had current starter out, it would be good to carefully compare that one with the old one after its rebuilt, carefully look at the nose section, see if you can see any differences in depth, positioning.... mainly on the gear, its shaft, etc. I'm betting rebuilding process is mostly on electrical side (like rewinding), probably not making material changes to the positioning of the critical components
On a really out there note, I wonder if something fell down inside bellhousing? small nut or bolt? Pretty random, but its always possible theres some small piece of foreign material in there where it shouldn't be, rubbing where it shouldn't be. Probably not, it would be way down on my list of items.... but i've seen crazier things.
The big wires on starter, if you keep having troubles, I'd carefully inspect them. I'm just replacing mine out of caution. They had a bunch of damage that couldn't really be seen very well until they had at least the front 3 or 4 feet pulled out. They had obviously gotten toasty at some point.... I notice my truck has newer starter on it (truck is 2003, starter is marked 2005, and starter motor outside condition looks a lot different then rest of truck too). I suspect that the fried wires and replaced starter are related. Maybe original starter had the solenoid lock closed, turn "on" and not release. Or something happened to make a dead short, for a short period of time at least. Maybe someone working on, and a wrench / tool just happened to hit both terminals at same time, make short for a few seconds? Things like that happen....
I pulled both of the big wires out of my truck, wanted to inspect whole length AND make sure they hadn't damaged anything around them. And was planning on replacing them anyways, so had to have all the way out. I did find a few things that were routed alongside them that got a little damage, mainly just some air lines, but nothing electrical except a small ding in a ground line from starter to frame rail (theres another ground line, maybe 1/0, that goes from starter ground bolt to frame rail, under starter... that one is worth checking out for you)
Once i got the big wires out, I found the damage on them was limited to fairly short section (maybe foot, foot and a half), and didn't do anything terminal to what was around it.... but had to get them out to really look at them / really look at the stuff they travel along with
If I needed to, I could have just added some insulation to mine, called it good, and it would PROBABLY be fine, but I'm replacing anyways. Burnt insulation opened up, never know how much water / corrosion could be inside rest of insulation. Or, maybe theres a break in there somewhere, that can cause huge spike in heat as current has to go through much smaller wire where break is.
One thing that concerned me with mine is, having damage inside cable I couldn't see. Its possible for a connector to get hot, kinda burn the wire inside, never make great contact again. Or, have some issue with the connector / wire connection that reduced current flow/increased resistance / increased heat.
Blah blah blah, i'm just replacing the cables and connectors (just talking about the big positive and negative cable I mentioned above) "out of an abundance of caution" I know if I dont, I'll always wonder if there is issue.... and I just dont like to have to worry / wonder about things. Its worth it to me to not have to think about it.
As a sidenote, when I was trying to get my truck to start (after I started having crank no start issues, I never looked at this before), I was able to do a cranking RPM test, and it showed the RPM as being a little low (190 to 210 rpm), they say the C12 ECM needs to see 250 rpm before it will fire injectors, so thats part of why i started digging into the starter wiring.... and why i decided to replace those damaged cables, just in case they were causing extra resistance / not flowing as much current as they should. Been going through truck and just trying to check & clean all relevant electrical connections....(making sure to hit all the ground wires)... make sure they aren't covered in corrosion, not loose, not damaged, etc. Just good long term maintenance in general, plus once you start having issues, never know if one bad terminal / connection somewhere is driving a bunch of issues. it certainly happens!! Hell, I've fixed a LOT of wiring issues on commercial trucks just by going through the wiring and looking for stuff that is obviously damaged... and fixing those damaged areas / parts. Or just cleaning, tightening connections.
Oh, as a sidenote, I pulled my dash, and found some connections there that had some corrosion on them. My truck was sold w cab armor stripped (no doors, roof, etc) I dont know how long it was left sitting w no top... but it shows plenty of sun damage, some water damage on and under dash. Not terrible, but its there. Also, dont know how long it might have sit somewhere with a missing turret ring cover?? My truck was runner, low miles (1200 miles, 200 odd hours). Pretty good shape overall, just lots of aging from sitting and sun
Make sure under the dash you dont have corroded or loose connections. I found the starter switch on dash had at least one wire a little loose, and a couple corroded.
Oh yeah, just out of caution, if I were you I'd check the other end of that wire going to alternator, make sure its tight, clean. I'd double check the alternator connectors too, make sure they are tight, clean (theres a couple specialty connectors on top of alternator, would be easy for one of them to be loose, they have locking ring on them that just turn to lock in place.... could have one pushed in place, but not locked, and it could be bouncing around, making intermittant contact.
An easy way to check big alternator wire might be to just run engine, and check voltage at each end of wire. Should only have very small voltage difference between ends (like .1 or .2 volts max). That big of wire should have low resistance, hence low change in voltage measurement at each end. Big voltage difference between ends would indicate its got high resistance somewhere.
Another wild(er) possibility could be loose belt causing alternator to have some slippage, have fluctuating speed, hence fluctuating voltage? Probably not, but these do have manual tensioner.... and I know mine has 300 amp alternator, at 28V thats 8.4 KW of output at full load, so its probably taking 10 to 15 hp to drive it, thats a lot of power through serpentine belt, esp with relatively small alternator pulley diameter...even with 12 ribs on belt, its a lot to drive, wouldn't be hard to have some slip with loose belt. Even the standard 150 amp alternator is nothing to sneeze at, since its 28v... that would be a 300 amp alternator at 12/14v... which is a good sized alternator, take a not tiny amount of power to spin it.
One last thing, theres a... "thing" back by the battery box, its like a big block of maybe brass (or maybe its just brass where the big wires connect). The big ground cable to the starter comes from here, and this "block" is fed by big wire coming off ground battery terminal. One big wire in, one big wire out, and two small wires that go... somewhere. I know all this because I had to unhook the cable going to starter to replace said cable. And I have no idea what exactly that ... block... does. Could just be wiring terminal block, convenient for manufacture when installing components....not doing anything but providing place to bolt components to, provide ground to them... but if I was chasing grounds on one of these trucks, wouldn't hurt to check it out... again tight clean connections if nothing else...
Well, i'm just rambling by this point. Just had a bunch of thoughts relating to this that I thought i'd share (esp since I'm currently working in this area.... tonight I might be making those big cables and putting them in). Steelsoldiers has been a great site for me, tons of great info here, learned a lot from this place (and had people from here help me, just had someone send me some very nice files today in fact), so when i can pay back the site by giving out some info / ideas.... i try to do that :)
PS. This might be something that you know (or can look up easily) Whats the part# for the starter? OEM vs replacement? Just asking in case I needed to replace mine (since it seemed to turn over a little slow). I looked on cat parts online, just couldn't find the right one (sometimes cat parts online is hard to navigate.... but usually I can find what I need.... for starter motor it was just drawing blank, though I suspect the truck had one part# installed, and it was later updated with new part, part#... which can make searching more difficult (only the original part # might be shown as direct fit, the replacement may not be shown as direct fit)
IridiumRed
39
NW MO, north of KC
Oh, one other thing - dont automatically trust the voltage gauge is reading correctly. I'd use a DMM to double check the voltage getting fed to it. Might have just bad gauge. That might be FIRST thing id do next time shes running, only take a few minutes, could save hours of checking / testing other things.... The MTVRs seem to be built really well in general, lots of nice components... but a bunch of the dash gauges aren't ones I'd necessarily put in that category. Maybe not BAD... but not premium either.
I know oil pressure gauges on dash can be off (whether thats the gauge or sender is a different argument, but its my gut feel that the gauge itself reads incorrectly on a number of these trucks... or at least it happens sometimes at least, and its not obvious - like a gauge reading nothing or maxed out.... instead showing a value, but the value is just off... so a voltage gauge reading incorrectly would be no surprise to me)
Sorry for double post, but I thought this was important enough to mention separately
