Mule M274 engine test stand
rosie
Pittsboro, NC
Hello all, thought you might be interested in seeing this test stand. We have used it for many years and it works great. When rebuilding a mule engine, or checking a used engine before installing, we attach or bolt the motor to the front of the vertical bracket facing the pull handle. As per the picture, the stand has its own fuel container. The great thing about this stand is that it allows you to pull the motor to wherever you wish. It is extremely stable, no balance problems, and allows you to run the engine as long as necessary outside without filling your workshop with fumes. When testing the engine at this elevation (close to the ground) it's easy to check oil pressures and temperatures from each cylinder (using a laser). If problems are already occurring with the engine, you can instantly shut it down, modify, or whatever, and if the bad boy is right, pull it over to the vehicle, install it, and get ready to work.
PS, this works really great; the test stand is a great tool for reasons of safety and convenience. If needed for understanding, and you would like to see a pic with an engine on the stand, PM us and we can pull one out of storage, and mount it for demonstration purposes.
1,132
Pretty clever. Makes moving them around easy as well.
rosie
Pittsboro, NC
It really does work great, is extremely stable and easy to maneuver. Hope the pics are self-explanatory, please PM if you need any assistance!
rosie
Pittsboro, NC
Good morning, crankshaft,
Test stand is all steel, base is 2 x 4 tubular and mating surface for engine 1/2 in plate steel. Opening cut with torch and ground smooth, welded to base. Casters and pull handle available at tractor supply shop. Nothing fancy but works great and very stable.
