Mule won't fire
Benharris
Virginia
I recently got my first Mule, love these things. It isn't running and I'm looking for more ideas.
It will crank, I'm getting lots of fuel at the T on the side of the carburetor, I've taken the carb off and cleaned it out. There was definitely some gunk in it. I drained the gas out of the tank and put in new ethanol free gas with stabilizer and Marvel Mystery Oil (just this first tank). I checked the in-tank fuel filter, looks good. I blew out the return line to the tank. Checked the fuel filter and sediment bowl, cleaned out. Checked the spark plugs.
It fires and runs for a few seconds with starting fluid, so I'm assuming I have good spark. What are the next things to look at? I guess the cylinders still aren't getting fuel for some reason, where do I start?
Thanks.
kubotaman
124
RI/MI
Are your plugs getting wet after you crank it over? If not, your intake hoses in the manifold may also be cracked and that will cause a no start/poor run condition.
kubotaman
124
RI/MI
Underneath the air shroud. They connect the tubes going to each cylinder to the intake manifold.
