- 31
- 57
- 18
- Az
So mysteriously out of nowhere my in tank fuel pump stopped working. The fuse was blown, so I installed another fuse and tested to make sure I had 24v to the wiring and I did, but fuel pump wouldn't work. I ordered a new pump for $575 from eastern surplus, installed it and same problem. I have power but it won't do anything. The fuse is on the 24v side right, not on the ground side? The Primary fuel filter cannister is completely removed and no fuel is being pumped up to the filter.
