will-m
- 10
- 8
- Griswold CT
My deuce has always been been a slow starter and I've decided that I wanna try to take care of it. I've always suspected that it was fuel leak back, because other then starting the truck runs great, has good power, no excessive smoke or oil consumption. I've checked the batteries which were showing 26volts, all the fuel filters are new, straight fresh diesel. I've also checked the intank pump and confirmed that it is pumping fuel. I've checked all the fittings for the injectors and flame heater return lines and can't find any leaks. The fuel shutoff is all the way in, and I've removed the cover to ensure that it cycles smoothly. Today I noticed some bubbles in the clear fuel line coming up out of the overflow valve on the injection pump after shutdown. From some other threads on this topic I'm thinking this may be the problem. I looked in TM 9-2910-226-34 but didn't see anything about how to check the valve. Any help would be great. thanks
