rickdavis81
- 84
- 28
- Rich Hill, MO
I've been tinkering with my multifuel dumptruck when I have spare time, which is never. Changed the fuel filters, still need to dump the tank and refill with fresh diesel. The previous owner said he replaced the ip because it was leaking diesel and couldn't get it to start easily afterwards. I went to check the timing and with the crank lined up on the appropriate mark the ip appears to be off half a tooth, maybe little more. My understanding is I can loosen up the 3 bolts on the pulley and adjust it to take care of this. Would being off that little bit cause hard start? The red painted tooth on the hh is on the pointer, but if I understand correctly when the ip is lined up on its mark it'll be towards the rear a bit, but it also sounds like the hh red tooth has nothing to do with timing. Also the fuel shut off cable was not hooked back up. Is it needed? Is it just for shutting off the truck? The lever is all the towards the front of the truck as if the cable was not pulled.
