Multiple Auctions of Exact Same Item Ending Exact Same Time? Best way?
Crapgame
343
Navarre, FL
I got wrapped around the axle in a bidding war over two auctions of the same exact item ending at that same exact time last week. By time the 5 auctions were over the final price spread was $100-300each.
I had set a higher max bid on two of the items, but with the outbid notification delays, it just became a mess trying to keep track of the lot number bid max bids, with the extended ending times.
In the event this happens again for items I seek, do any of you have a recommended method to effectively manage, say up to five bids for separate auctions for the same item so you don't get stuck owning 3/5 at the end of the bidding?
I just tried, I couldn't even advance search to find the five ended auction events to list as example.
NDT
7,522
Camp Wood/LC, TX
Do you have the auto-refresh pressed? When the auction gets down to the last minutes, I refresh a lot. Of course if someone bumps you, the auction is extended, so you can convince yourself to blow your budget on more crap you don't need.
gimpyrobb
dumpsterlandingfromorbit!
27,791
791
Cincy Ohio
Thats pretty much how I do it. One window open for each auction item. I hit refresh on the "my active bids" page and watch for one to go "not green". Then I go to that window and change my bid.
