latvius
- 13
- 8
- Ariton Alabama
I actually did this a while ago and meant to post about it, so better late then never.
I found an article in a magazine posted online about how to install these, in a nutshell you use a conduit hole cutter. Don't use a hole saw, they said not to but I had to try it to confirm they were correct.
Also if I had to do over I would have done less gauges farther apart. I also bought these nifty crimper set so I could do a plug so when I pull the dash pad off I can just unplug them.
