Murphy strikes again!!!!
AMGeneral
115
Connelly Springs, NC
Well,I just thought I was free and clear after buying wreckerman's M915,but evidently "murphy" had a delayed reaction.
I was getting the truck ready for the trip to VA on wed evening to finally pick up the other M172A1 in Blackstone VA but,Murphy had other plans.
While driving the truck to it's parking space,I get a loud BANG and the truck immediately drops down on the pass side.
Needless to say,the tire split from the rim all the way to the tread,so it's down till the tire store is open tomorrow AM.
This probably won't be cheap.
wreckerman893
Possum Connoisseur
15,618
2,013
What did you do to make "Jessica" mad at you.
I'm sure Mr Murphy called ahead and told them to give you the "lube up special".
I suspect the red paint on the tires was an indicator that it was time to replace them.
At least it happened at low speed close to home.
EMD567
Driver for the Ga Mafia
47
Aiken SC
Better that it happened at home, at low speed. Can you imagine what that would have been like at speed, with a load?
While I am here, does the Military have a pretrip inspection for the vehicles before driving them?
How many MV owners do a pretrip, or even know how to do a pretrip?
Or do you just get in a drive?
AMGeneral
115
I agree,it was better here vs having to call a tire service along the road.
BTW,my personal pre trip inspection is as follows.
Check all fluid levels(everything) and note any leaks.
Check belts,hoses and underhood electricial wiring condition.
Check all tire pressures,including the spare and look for any odd wear and objects.
Check all lights(head,tail,turn,stop and B/O).
Fire the engine and check for correct oil press and note any odd noises and smells.
Make sure the 5 gallon can is full on the running board and make sure I have at least 2 extra fuel filters,a set of belts,and 1 gallon each of engine oil,gear oil,and a tube or 3 of grease,plus 5 gallons of drinkable water(for me or the engine).
This is for any trip over 30 miles,any trip less than 30,omit the 5 gallons of fuel and water.
All this plus the ovbious tools and spare parts.
EMD567
47
Aiken SC
That is a good pretrip. Do you check the tire with a gauge, or just "thump um".
Ferroequinologist
Resident railroad expert
736
Liberty Hill, SC
Geeeze Brandon!
I supposed you weren't planning to go today, as I hadn't heard anything. If my back is better, I may go with you on Wed. if you want.
Glad it was something 'simple'
jasonjc
283
Gravette Ar.
The -10 for the truck has a PMCS ( Preventive Maintenance Checks and Services ) list. That will walk you thought ever thing you need to look at befor, during and after driving the truck.
NDT
6,150
Camp Wood/LC, TX
That's what happens when someone puts a Sumitomo tire on a US military truck. Your 915 has probably been trying to pop that one for a long time.
AMGeneral
115
Geeeze Brandon!
Yeah,still waiting on permits and the state of NC,I plan on leaving about 5PM on Wed evening and getting an early start on Thurs coming back,you're more than welcome to ride along.
AMGeneral
115
I blame NO ONE but myself ,but that being said,$300 later I now have a NEW steer tire for the 915($3300 for a set of tires:shock:).
Now i'm back to waiting on the state of NC to make up their mind whether or not they wanna allow me to tag this truck,then I can get the permit and be on my merry way.
NC law states that you must provide documentation a proper saftey inspection BEFORE they will issue a tag of any kind ,Then it is faxed to Raleigh and they decide if you get a tag or not.
Which means you either drive your vehicle illegally to the inspection station or purchase a permit from the DMV to drive said vehicle to the inspection station.
Kinda messed up Huh?
