Mutt Battery Replacement
rickf
1,636
Pemberton, N.J.
51R is going to be about as close as you are going to get. They are a little shorter in length and a little narrower. I put a small strip of plywood lengthwise along the non terminal side to catch the tie down.
Rick
Hightechken
NE Wisconsin
I used the smaller size batteries in mine, And "shimmed" the batteries with that hard pink styrofoam insualtion to make up the difference. Even here in cold country, The smaller batteries have plenty of power to start it, And the styrofoam is holding up well as a shim material.
