MWO meaning
LanceRobson
220
Pinnacle, Stokes County, NC
I suspect that the way you have the MWOs listed is not quite correct. The numbers you have listed as 201, 204 etc are most likely 20-1, 20-4 etc. If you do a web search for "HMMWV MWO list" take a look at the infmotorpool link and you'll find what you're looking for. If the link doesn't show up in your search engine PM for the link.
Best regards,
Lance
MtnSnow
17
NSL, UT
MWO 9-2320-280-20-1 Trk, 1 1/4 Ton, M998 Series ADDS POWER STEERING COOLER
MWO 9-2320-280-20-4 Trk, 1 1/4 Ton, M998 Series, Steering Column Insp/Bracket Installation INSPECTION/REPLACEMENT OF BAD BRACKETS
MWO 9-2320-280-20-6 Modification of 1-1/4 Ton Vehicles, M1097, M1097A1, M1025A2, M1097A2, M1113, and M1114 AIRLIFT BUMPER REINFORCEMENT KIT (Not adding the airdrop bumper itself, but adding a plate to it)
MWO 9-2320-280-20-7 Modification of 1-1/4 Ton Vehicles, Carriers: M998, M998A1, M1038, M1038A1, M966, M966A1, M1026, and M1026A1 CROSS MEMEBER REINFORCEMENT (allows M1101/M1102 series trailers to be towed to humvees WITHOUT the Airdrop bumper)
MWO 9-2320-280-35-1 Trk, 1 1/4 Ton, M998 Series PARKING BRAKE LOCATION CHANGE (drive line to brake itself)
MWO 9-2320-280-35-2 HMMWV, Seatbelt, M998/1038/1037/1042/1035/966/1036/1025/1021 3 POINT SEATBELTS
MWO 9-2320-387-20-1 Rear Differential Cooler Modification Kit M1113/M1114 ONLY
Retiredwarhorses
4,626
Brentwood, Calif
or most likely the Pvt scribed a 5 instead of a 2.....but many MWO's are not done at the unit level, but done at reset, or teams of civilians go from unit to unit and do them. I've witnessed first hand back in the 80's all my units MUTTS and m35A2's getting SLEP's applied...in the case of the MUTTS it was ROPS, they installed ROPS on deadlined jeeps so cannibalized that the only thing left on it was the body and tired. And then a few months later...they all went bye bye and were replaced by the HMMWV, tax dollars hard at work once again.
