My 1st HMMWV from GP
majorhavoc67
Lincoln NE
First time I ever bid on a GP truck and I won. Not sure if that's a good omen or bad? I'm sure time will tell. Does anyone polish the clear gauge cluster faces when they are worn and cloudy or is their a source to buy the clear lens without having to buy the entire gauge? I was a medic then medical NCO in the Army for 22 years, so when I saw this M1035A2 I figured it was a sign. lol.
Maxjeep1
1,912
Las Vegas Nevada
Clean them with a baby wipe or something to get the dirt off and use aluminum polish and a microfiber towel to polish it back to new. Works on the Speedo sticker too
sue
343
tulsa OK
Headlight restoration kits will work if it's really bad. Otherwise, paint is a plastic so any product that restores the appearance of paint will work on the gauge faces too.
It’s funny we got ours from the Nebraska national guard in Lincoln, about
4 years ago 6K miles
runs great.
frauhansen
538
switzerland
*snip* Does anyone polish the clear gauge cluster faces when they are worn and cloudy "snip*
Mine where cloudy as well. And i pollished it with the same you would use for headlights.
Just bought a set at some random car parts store.
This exactly: https://www.walmart.com/ip/Mothers-...s_ad_id=565706&campaign_id=9383&sharedid=cnet
I used it for plastic headlights and for the gauges as well. But with one very important addition!!!
The polishing plates are too large for the small gauges in the dashboard. You would then grind the paint off the bezels.
So I bought a smaller sanding disc and smaller sanding pads on ebay. I sand everything down with these when wet and then use the polishing paste and polisher from the set.
Pay attention to how you sand the wheel. The sanding pad easily gets caught between the glass and the frame.
before
after
juanprado
2,866
Metairie/La (N'awlins)
The bows on that model are rare as they are taller than the regular ones for the ambo tops which are one piece.
Sportsmanguide had the tops years ago before the flood of hmmwvs.
Did not realize this model was now being surplused.
Love to see interior pics. Nice score
majorhavoc67
Lincoln NE
before
after
Cool! Does the glass pop out of the bezel or are they fixed?
