- 1,199
- 453
- 83
- Spartanburg,SC
After reading 05blackduramax's thread on converting to an A1, I decided to post some pictures on how I accomplished mine. I installed an A2 spare tire carrier and boom assembly with minimum modifications. The first picture shows it before I cut and rewelded the grab handle. It has to be moved forward since the intake snorkle was swung forward to gain more clearance for the wider spare. Picture # 4 is an upward shot showing how I spaced the forward diagonal brace with longer bolts and spacers to allow the tire to ride as far forward as possible. I also removed the hooks for a soft top since mine is a hard top cab. Not necessary but I did. The last 3 pictures show where I cut about 3" off of the aft brace mount for clearance for the bed since I couldn't use the diagonal brace anyways. The A2 carrier bolted right in place of the old one. All in all, I spent more time looking and thinking then actually work on the swap. I have raised and lowered the spare a few times and am happy with it. This post is also for Karl Kostman whose thread prompted me to do this. Many thanks to Acme66 too for some of the ideas I used.
