cyamaha2007
- 3
- 18
- Warrenton Mo
So i woke the deuce from a 6 month slumber after checking all the systems and changing and topping off all fluids it started right up but the brake pedal would go to the floor with full air pressure. So before moving it i do some detective work to see a crack in the cast iron part of the airpack. I drained the air tanks and oiled the pack before i put it away. Did the cold do this. Its a hairline crack. Uggh The brakes worked perfect way better than a friends deuce that he rebult everything. Thanks
