My CUCV
DokWatson
Wasilla, Alaska
Id like to know where to hook up sending units for engine temperature and oil pressure, I don't like not being able to see that.
Also want to make sure that when I go crossover, will any 1985 2wd box work?
Thanks.
rnd-motorsports
Evart,Michigan
The oil pres sending is in the same spot as a small block back driver side top of block next to vac pump take out sending unit and put tee in replace sending unit and install your gauge for the temp there is a sending unit on the front driver corner or pass rear corner in the side of head close to the end you can put a tee in either of those
Warthog
231
OKC, OK
Thanks.
Hey, How is Sarah????
All the tech manuals with wiring diagrams, parts loctions, part numbers etc. are avaiable for free in the Resources section.
You need to visit the CUCV forum and at the very top is the CUCV Wiki. It has all the manuals listed and links to download them. And then read the FAQ sticky as it has alot of tips/tricks listed.
What are you crossing over too? Need more info.
DokWatson
Wasilla, Alaska
Bought this truck from a buddy. He might know who Sarah is.
