CabbagePatchDeuce
- 0
- 0
- Waycross Ga/Edgewater Fl
Trying to get my multi fuel running but it won't even fire on wd40 any sugestgens?
The fuel cut-off lever is not physically attached to the cable that is operated from the dash. It only ends up pushing it into "cut-off" position and returns to "run" position by the internal IP mechanism.Push the fuel shut off, that is located on the dash, back in. Go under the hood and find the cable that is connected to the shutoff and rotate the lever on the pump clockwise and it should start.
I should add that the "gas" pedal is linked to it via a spring and a few taps on the pedal may put it in "fuel' position and get you started.The fuel cut-off lever is not physically attached to the cable that is operated from the dash. It only ends up pushing it into "cut-off" position and returns to "run" position by the internal IP mechanism..
I'm aware Gimp, just for future ref, I may need a reminder myself...just wait till you turn 65+....This has been fixed guys, he said what it was one page one. YEAH team!
You may have to remove it and give it a good cleaning, so that it operates freely. Referring to the image below, the lever must slowly move by gravity when moved up and let go.
tm9-2910-226-35 (1964)what tm did the picture come out of ???
