My first 5-ton purchase from GL
Stan
St.Louis, Mo.
RE: Re: My first 5-ton purchase from GL
Nice catch, We're starting to get a decent handful of Missourians on here. Just where are you and your truck. If you need a hand let me know if close no problem. Good luck
steelsoldiers
3,971
Charleston, WV
The 809 series trucks are great. One issue that seems to come up with some frequency is a gummed up sprag control mechanism. If you are driving it home, make sure that when you are going from 1 to R you hear a thunk. That is the sprag control valve/piston working. When I picked my 818 up, the sprag was stuck in reverse and I had to pull my front drive shaft to get it home. If you are going forward or reverse and the drive-line winds up and goes pop or thunk every so often, the sprag is stuck. Before removing the drive-shaft, jack one front tire off the ground top relieve any wind-up. If you don't, the drive-shaft might break your arm or worse.
Good luck and keep us posted!
