My First Deuce Arrived (Long post with Pics)
JeremyN
Provo, UT
The 1970 Deuce/Shop Truck (M109A3), I bought from Army Trucks Inc. (a prop company out of southern California), arrived a couple weeks ago, sorry I've been too busy to post about it until today.
Wow, now that's a truck! Would you believe I've never owned a truck of any kind in my life until now (my first vehicle was a 1970 International Scout though). But I always say, if you're gonna do something, do it right.
Army Trucks Inc needed to pick up a truck here in Utah from Hill Air Force base and so they agreed to have mine delivered to me for a very reasonable rate. So no recovery required!
Overall it seems to be in great shape, the engine looks good, as far as I can tell anyway, tires are in pretty good shape. Everything is clean. My main cosmetic complaint is that when they painted it for movie use, they were pretty indiscriminate. Lot's of overspray, inside and out. But as a bonus it seems to have kept the rust at bay, I'm pretty hard pressed to find much rust anywhere. Also, according to the paperwork, it had about 44,300 miles on it in 1997 when they bought it from the military, and now it has 44,600 miles. So needless to say, they didn't put very many miles on it.
When running all the gauges seem to land about where they should, with the exception of the volt meter going high into the red. Also, I seem to have recalled reading either here or in the manual about there being a low air pressure buzzer that should be heard up until the pressure is safe to drive. I've never heard a buzzer, is this normal?
The night it arrived I had to drive it from the street into the parking lot at my office, where it's currently stored. I had read the manual a couple of times and I thought I knew how to operate it, and I did okay, but for the life of me I couldn't figure out how to turn on the headlights. So I had drive through the parking lot in the dark. Back to the manual I went until I finally figured it out. (For the record, it was having to hold up the release lever that threw me).
Let me start by saying that my auto mechanic abilities don't yet extend much beyond knowing how to change oil on my car. That being said, I'm really excited to learn more and I hope you folks here don't mind me asking the occasional question.
I was able to get insurance from Safeco for a mere $81 every 6 months, and I was able to get it registered here in Utah as a Vintage vehicle. In fact my first drive in the truck was about 30 miles round trip through town to take it downtown so they could verify the VIN in person.
Now I've driven fairly wide variety of vehicles in my life, the biggest being a motor home. And I've driven close to a million miles in a stick shift, so I thought I was prepared for this, and in fact I think I did okay, but it was rougher, louder and harder than I had expected, and I thought I was prepared for a lot. Let's just say, I'm rather happy I didn't have to drive it back from California as my first drive, that would have been quite intimidating.
For you softie first timers like me, here is what I learned quickly. Be prepared to shift FAST. When stopped at a red light, I hadn't expected that I might need to shift 1st, 2nd and 3rd before I was even through the intersection. It really does feel like driving a semi-truck I think. And yes it is LOUD! Bring ear plugs and don't plan on having any meaningful conversations with your passenger.
Also, I'm accustomed to the steering wheel of a vehicle spinning back quickly after a turn, however in my deuce, you may need to help out a bit, or be patient. On one my first right turns at an intersection (I think it was the first intersection where it was green and I didn't have to come to a complete stop, so I already had some momentum), I just about oversteered into the curb on my right because the wheel didn't spin back to straighten out the truck as fast as I had expected it to.
Also, my truck shook a lot at first, especially as I approached 40mph. For now I'm blaming it on flat spots on the tires due to sitting for a week before it's first drive. Though it might be my font drive shaft (more on that below).
Watch your RPMs! It's really easy to go over the limit, especially in 3rd gear for some reason.
Hills can be a bit scary too, I only had one hill where I had to hold the truck from rolling backward at an intersection, while I waited for the light to change. Can I just say that drivers are stupid! Do you have any idea how close the car behind me got? I swear they were an inch from my bumper. Needless to say, I chickened out and held my position with the clutch and gas rather than the brake. I need to get some more practice on hills before, I do the the proper way.
Speaking of which, in the manual it says you can use the hand brake as a way to keep yourself from rolling backwards. I didn't find this to be very effective for me, at first it was too loose to do any good at all, and by the time I tightened it enough to have any holding power at all, it was too stiff for me to pull. (Probably doesn't help that my arm strength isn't all that, too many hours in front of computers…) Anyone have advise? (Other than hitting the gym)
Now to my big mechanical question, as you can see in the included pictures, the front drive shaft has a pretty significant dent in it and is also bent a bit. My guess is that somebody high-centered it on the drive shaft. How serious is this issue, especially if I'm not engaging the front wheels? Could this be contributing to the shaking that I was experiencing at higher speeds (though it did seem to get better after we'd driven for a while).
Last question for now, I haven't looked through all the manuals, and I haven't figured out how to get power to the shop truck part. I noticed there is a plug behind the cab, but it has a connection type I've never seen. Is this where you can plug in power? And if so, where would I get a connector like that?
Okay that's it for the questions and advice for today here are some pics:
JeremyN
Provo, UT
Couple of follow up questions I forgot in my main post.
As you can see, they used off the shelf car batteries, is this common?
Also the truck vibrates so much at speed that the mirrors are pretty useless, all I see is blurry cars. Is this also common? I put one of those stick-on convex mirrors in the corner, and that helped a lot.
Also, let me say that though I bring up a lot of issues and some surprises, I'm THRILLED with my purchase. Even if everybody at my office is now convinced their boss is crazy.
glcaines
2,586
Hiawassee, Georgia
Nice looking truck! Brakes are the most important part of the truck. Make sure you check the brake fluid level and top it off with DOT 5 fluid. I wouldn't drive the truck until you fix the faulty low air pressure alarm. Also, never, never slip the clutch on a deuce. This clutch is designed to be let out immediately, like on a tractor. Don't worry about shifting the transmission fast. Just take your time and your transmission will hold up better. Use the transfer case in low range to start off when needed. I start off in low range about 90% of the time and 100% of the time in reverse. The transfer case is synchronized and easy to use. I would recommend replacing the front drive shaft. You can find a replacement very cheap.
Akicita
Eastern Pennsylvania
Buzzer: At best, the wire to the buzzer my be loose. Easy fix.
Hills: You'll wear out your clutch if you "hold" the tuck by letting the clutch slip for a long time. Find a hill and learn to shift from 1st to 2nd in low and high. It may take some getting used to but it's not complicated.
Handbrake: You need to adjust this some more.
Car batteries: I have two car batteries in my Deuce. I like that I can replace them when necessary at any automotive store, Sears, and dozens of other places.
Damaged shaft: I would replace that if it was my truck.
Unusual plug: I think you were looking at the plug used to jump start the truck. There are two kinds and I haven't a clue which one you have. Neither looks like a standard electrical recepticle of the kind you have in your house. You need a cable with the appropriate plugs at each end to jump a truck.
Enjoy your new toy !
Whitey
Central Maryland
There are two types of plugs for the "slave cables":
-2 prong, older style
-Single large round plug, NATO standard.
Both are very easy to find in a couple of different lengths. You'll use your second MV to jump start it if needed. And, yes, I said your second truck as most of us don't have just one for long! :driver:
colelkhunter
any driveshaft shop worth their salt should be able to fix your front shaft without much todo. Find some back roads and practice driving. Only way to learn. Good looking truck and good luck with it. On the buzzer issue......was the air pressure ever low enough to activate the buzzer? Mine routinely holds air just fine, so sometimes when I get in there is no buzzer. It will only go off if the pressure is below 60 psi on the guage if I remember correctly. Next time you get in turn the accessory switch on and look at your pressure guage. If it is below 60 and no buzzer check the power to it first, someone may have unplugged it so they didn't have to hear the annoying noise.
FMJ
37
Las Cruces, NM
That bent driveshaft is from a MORON lifting the truck with a forklift. . .
Pull that front shaft until you can have it re-tubed or replaced, before you destroy your transfer case, or have that driveshaft exit the vehicle at speed.
your vibration should go away.
shootiniron
13
Escalante,Utah
You commented on going through three gears before getting through an intersection,sound like you may have been in LOW range.Like FMJ said,remove the front drive shaft and your vibration will go away as well as save the T-case.
Welcome to the site.The search button here will become your best source of info....besides the TM's of course!
FMJ
37
Las Cruces, NM
Check your voltage with the batteries connected and the engine running to get a true voltage reading. If it is too high, I think that there is an adjustment.
Yes, there is an adj. screw on the gen underneath an access screw/cover, but check to see if it is really high first.
Darwin T
10
Port Arthur, Texas
the plug up high behind the cab is power to the box and is not the same as the slave cable plugs (either two pin or nato) i think it is 110 volt. i am looking for one myself.
JeremyN
Provo, UT
Thanks for the tip, but nope, I'm in high range. It was in LOW when I got it off the truck and took it for its short drive into the parking lot. Low was so low that by the time I pushed the clutch in and got the gearbox into 2nd gear the truck had slowed down so much I needed first again. :driver: Looks like I certainly need some practice. And I may have been exaggerating a bit, but I was certainly in 2nd and well on my way to 3rd by the time I was through the intersections.
Sounds like I'll be removing the drive shaft first thing and looking for a repair or replacement, and then trying to track down if or why the buzzer isn't working. After double checking fluids of course, especially brake fluid.
This is fun. Thank you everybody for the advise so far.
JeremyN
Provo, UT
I like that nobody has asked why I bought it. After all do you really need a reason? So far of everybody who's asked me about it, only one guy failed to ask "Why? What are you going to use it for?" All he said was, "Aim for the hippies." :p
But for those that are curious, I'm a bit of a prepper, and I found out about these from that post on SurvivalBlog.com. Seemed like an ideal "get out of dodge" vehicle for us to get to our cabin with all of our preps and solar panel system, if someday we needed to, though I kinda doubt it'll ever get that bad.
So in the mean time, it's going to make trips to HomeDepot a lot easier. And we are actually toying with the idea of turning it into a mobile video production studio for my business. Need to figure out air conditioning if we do that though. Computers don't like heat.
kwiksilver
Charleston, SC
When they ask me I say "for running over $h1t"
