My Flexplate Story
Krausk
Ky
Ok so I posted back last summer about my engine making a growling sound. Let me say that I searched high and low for information about a bad flex plate and or bolts. I only found one video online and mine really didn’t sound like this so I was thinking maybe I had a bad transmission pump on my 87 model with the 6.2 diesel. Due to work and life I just put it away last year. I got it out couple weeks ago and removed all the necessary crap to be able to remove the flywheel cover. Low and behold there were NO bolts left in their respective holes holding the flex plate to the crankshaft. So, I’m now just waiting for my replacement bolts. Only thing I’d like to know is what are the torque values - I don’t want to read the manual either. I’d appreciate the help. Anyway GM products truly do suck. They couldn’t put a dimes worth of loctite on the bolts at the factory? Really? First rate manufacturing processes there. Have a good one and thanks for the help.
porkysplace
1,487
mid- michigan
Well I'm busy this weekend maybe I'll have time to search next week.
Well I had a spare minute only needed
(0.42 seconds) first hit has them
http://lmgtfy.com/?q=HMMWV+flexplate+bolt+torque
dilvoy
25
San Francisco, Ca.
From memory, 60 lb ft for the flex plate bolts. Flex Plates cost less than $100 so it is a good thing to replace, because your bolts fell out somehow and the ring gear does wear, especially if the vehicle was difficult to start.
Krausk
Ky
Flexplate new bolts new blah blah. I’ll just check a GM website for forqur values thanks for those who do help.
Action
1,556
East Tennessee
were the bolts in the cover when you took it off? How did you start the humvee without the flexplate attached to the motor?
NDT
6,303
Camp Wood/LC, TX
This dude is in for a rude awakening about HMMWVs when (soon) his glow plugs and controller fry, alternator burns out, transfer case vampires, CV joints blow, Cadillac valve and fan clutch crap out, starter breaks off, IP dies, wheel passes him up . . .
ken
25
Houston Texas
The dowl pin was probally the only thing keeping everything spinning together. I would have to give GM kudos for this one. They make really strong dowl pins!!!!!!!! But as far as the bolts go. Someone in a motor pool somewhere left them out. There isn't enough room for them to back all the way out. Even if they could have, They would have broken the trans case or cover as there is very clearance between them. It would have been inspected at some point in 20 years making that noise. So a factory miss step it highly un likely. It is highly likely the engine was replaced in service. Any way once you get it back together, I hope you have fun with it.
1,174
FWIW, here's your last thread. You had diagosed it as needing an engine, then a transmission pump.
All relevant to your current issue(saves everyone asking the same questions again).
Next time, simply update your existing thread.
I've closed this thread due to the "attitude".
If you'd like more help, PM me and I may reopen it for you.
4,744
Glad the attitude here was so helpful. Even more so when I get emails from people saying to delete their accounts from it. There was wrong from all sides here. But this group should be about sharing knowledge, not being condescending with it.
No more let me google it for you links either. New rule.
