kcobean
- 3
- 18
- Sterling, VA
I've been reading everything I can get my hands on regarding maintenance of the HMMWV in preparation for mine to show up. Here's my plan for my first week of ownership:
Full tank of fuel (the needle in the auction pics looks like the tank is very near empty) with Power Service Diesel Additive. https://shop.advanceautoparts.com/p...oz.-1080/7080778-P?searchTerm=diesel+additive
Oil Change: https://shop.advanceautoparts.com/p...19913/8020590-P?searchTerm=rotella#fragment-2
Oil Filter Change: https://shop.advanceautoparts.com/p/fram-extra-guard-oil-filter-ph5/5141079-P?searchTerm=fram+ph5
Diffs/Hubs oil change: https://shop.advanceautoparts.com/p...-gear-oil-vv831/7070003-P?searchTerm=gear+oil
Transmission/T-case Fluid change: https://shop.advanceautoparts.com/p...g/8130014-P?searchTerm=mercon/dexron+at+fluid
Coolant change: 25/75 mix. Could use a recommendation of a coolant as I know that normally green and orange don't mix and the TM calls for Ethylene Glycol based coolant
Full inspection of all wiring, hoses, boots, belts and seals.
Anything I'm missing or any recommendations? Is an alignment a good idea?
