chgofiveo
- 1
- 0
- Chicago IL
I went with the Donaldson M070028 and used compression clamps top and bottom instead of the old standby "D" style clamp. I also left the heat shield the standard size and centered it on the muffler, welding 4 nuts onto the muffler to make it stick out a bit. I was able to position it and use the same mounting bracket under the top compression clamp. l painted it with high temp flat black prior to the install. After a few heat ups and cool downs, I gave it the spay can "Cammo" look. The noise difference inside the cab, while driving is, in my opinion, cut in half. It very much STILL has that great Army Truck sound, only not quite as loud. Great improvement...Total cost: $120.00... Let me know what you think
