dmc-4359
- 1
- 18
- Chapin, SC
Hello all, I thought it might be a good idea to introduce myself since I am new to the forum. Yesterday I purchased my first m1009. It is an 84, has evidence of several poorly attempted wiring updates done to it and ran fine from the dealership to my house, at which point it is now just sitting and won't start.
Here is a pic I took just after I got it home:
First a little about me, I'm a Chevy guy though I'm partial to DeLoreans as well. I cut my teeth on a 55 Belair which I still own and have since purchased another because it seemed like a good idea at the time (grin). I've never owned a diesel engine, nor wrenched on one so this is brand new territory for me and I'll go ahead and apologize in advance for a likely amount of ignorance related to terminology and common sense. I have CD with a world of information on the 6.2 heading my way but I don't expect it to arrive for several days.
So, on to my question;
I've searched this forum a fair amount but cannot seem to find a suitable answer to my conundrum. My m1009 will not engage its starter. If I turn the key at this time, I get nothing but a light click under the dash...which as I understand is the starter relay. I have traced the wiring enough to know that the starter is still 24v with good connections but the signal wire to the starter's solenoid has undergone some mcshady good intentions treatment which doesn't allow me to trace it out very well. (I'm used to working in my shop, not outside with this 'darkness' thing I've read about) My question is a bit two fold; first, can I jumper the solenoid on this starter in the same way I can a regular 12v starter to test starter functionality without removing the starter? Also, would I hook 12v to the solenoid post or 24v?
Ok actually, now that I think about it I have another question. When I bought the truck, I was told that the ignition key cylinder was broken and would not spring back automatically from "start" to simply "on". I had no trouble twisting the key back a hair to disengage the starter after the engine cranked. I let my friend drive it to check it out, after telling him about the key starting issue, and it was after that run that the starter quit working. He said he didn't hear anything out of the ordinary after he cranked it and drove off so I suspect I have an electrical grimlin but am still curious. If he left the starter engaged while driving, would it react in this manner or would it have made a world of grinding sounds and started spitting pieces of a flex plate or starter gear out?
Anyway, thank you for taking the time to read my drivel if you did and perhaps even taking a crack at explaining my starting woes.
![](http://ls1dmc.com/images/blazer1.jpg)
