my little wrecker stuck
Jakob
Louisville, KY
Looks like you were dragging your axles in the mud. Once that happens, you're pretty much done for. Nice recovery though! Are those XL's underneath all that goop?
ida34
33
Dexter, MI
Did you squeeze those tires on the stock rims? I think the standing water might have been a clue. I think you just stuck it for fun.
SrIrie
Oregun
Were you able to strait pull it or did you use a snatch .....................................block
:popcorn:
rizzo
Port Huron, MI
Jakob, I could still move the truck back and forth. yes XL's
Ken, about 2-3 months ago. the motor is so weak I don't even take it out on the road.
chuck, yes stock rims, just like my other deuce
Sr Irie, straight pull to a tree. I used almost the whole length of cable. used high gear in the PTO. I had to rev the motor at the end as I was climbing out of the muck. It dragged me through a couple truck lengths of that muck.
Beast, ????
rockman
Kingsport, TN
Looks like you used almost all of your cable. With it mostly off the drum, did it pull easy? Glad it was a sunny day and not a down pour.
CliffW, I think I know those girls...
