My lower ball joints are different!
Hmmwv Brit
Virginia Beach
Hi all!
I'm replacing a lower ball joint on my M1025A2 and the one thats come is different to any parts I've found on the web. It has a double thickness plate. Anyone know if this is a heavy duty upgrade or similar? It has no part number on it. The holes are larger like the newer ball joints.
frank8003
4,984
Ft. Lauderdale, Florida
Coug
4,306
Olympia/WA
Hi all!
Where is it that you ordered it from?
Hmmwv Brit
Virginia Beach
Thanks for the replies. There is no part number in that location, it's a lower ball joint. I think it must be an uprated ball joint. This HMMWV was a GMV, probably something to do with it. The joint itself was fine, I just swapped the gator of the new joint and reinstalled it.
Retiredwarhorses
4,167
Brentwood, Calif
A0/A1 lower ball joints are 3/8 mounting holes, A2 on up are all 7/16 mounting holes.
if your truck is an A2, it should be 7/16 Moog problem solver BJ’s
