My M35 Turbocharging Project.
1,128
You're truck looks awesome, what color is it and do you have any more pics of it?
1,128
That is a fine lookin' deuce! :) [thumbzup] :) [thumbzup] :) [thumbzup]
mangus580
282
Western NY
How about how the marker lights are wired in? I have a set I bought for mine, including a batch of 5 for accross the back.... just havent got around to installing.
RDD, FLMV.net has the proper marker lights for it...
Deuceswild
Sheboygan WI
Rizzo,
I used N.O.S. Military marker lights, picked them up from ebay, there are 3) on the rear (center) 2) on each side of the box, red & amber and 2) up front on the sides of the parking light guards.
Jwaller,
The spot light is civilian from 60s era, purchased off ebay, rewired for 24 volt and sprayed with 383 green CARC sub.
mangus580,
2 seperate harnesses, 1 forward and 1 rear, both are fed from a circut breaker panel which I installed under the dash (24 volt ) 15 amp the lights are are controlled with 1 30 amp toggle switch just to the left of the hand throttle, Will send Pics.
Red devils dude,
You are correct about the color and manf. of paint :wink:
