DCIV
- 0
- 0
- Morristown, TN
Finally got my M998 today and have spent all morning going through it. We had to jump it off the trailer but then it drove nicely around. Parking brake wasn't holding for anything and was pretty much worthless, looked up in the manual how to adjust it....holy pop was that simple. Twist knob on e brake until tight, pull up, and if too much then loosen a little! You know how many vehicles I wish they would make that simple! So I took it for a small ride and going up our driveway, its a 25 degree angle, the humvee surges....kind of scary actually. I figure some water in the diesel and again go to the manual and find where the bleeder valve is, bleed out some fuel into a bucket and there is a very very small amount of water but nothing bad. I also put some stabilizer in the tank. Charged the batteries for over 3 hours and they barely wanted to start. Not as bas surge but still enough that it scares you a little. Odd that going up other hills the thing has plenty of power and feels great. So why would it surge going up my driveway and run great everywhere else?
Other notes, I had driven a true H1 but never a humvee. From the pictures the gear shifter and e-brake look pretty big, well they are tiny in real life. Also, wow you sit close to that steering wheel, closer than I would ever in any other vehicle. My trans fluid looked basically brand new, but my engine oil was a little low. So were the tires (what PSI do people like running them?). Mine also has a coms box on the roof between the passenger and driver, I dont have any of the headphones but I bet if I did it would work. Mine came with the tarp coving the rear bed, I took that off as I like the looks better. Overall I am super happy so far, just need to fix a small surging problem and get some new batteries.
Thanks in advance guys!
